Bog problems!
Discussion in 'Tech/Mech General' started by LeeFrancis76, Mar 24, 2016.
  1. LeeFrancis76
    LeeFrancis76
    Feb 29, 2016
    5
    3
    Weston-Super-Mare
    The flush on my toilet seems to be very inadequate, it just provides a trickle, rather than a good flow.
    its a dometic toilet, that does not have a cistern, but is just provided from the fresh water tank, which makes me think it is down to the power or flow from the main water pump. However the taps in the sinks provide a pretty good flow and power, more than enough to give you trousers a soaking in the wrong place at the wrong time!
    So, has anyone had a similar problem? or know how i can solve this?
    It was suggested that I should upgrade the water pump, but this seems unlikely due to the performance of the taps.
    any ideas anyone?
    • Like it Like it x 1
  2. Al-Di
    Al-Di Funster Life Member
    Mar 15, 2014
    1,084
    4,388
    prestwich
    remove the feed pipe to tiolet and retry, see if theres a blockage anywhere in system,
  3. maxi77
    maxi77 Funster
    Mar 20, 2013
    352
    209
    Kingdom of Fife
    Mind you a standard house toilet flush will just about fill your cassette.
  4. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
  5. Mel
    Mel Funster
    Oct 6, 2012
    2,137
    2,158
    De Haan Belgium
    I had the same problem on a Rapido.
    Rapido told me to remove the valve very near the toilet.
    It is to stop too much presure geting through.
    But mine did not allow enough pressure.
    Mel
    P.s. Also Dometic
    • Informative Informative x 2
  6. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    3 16833 Vacuum breaker
    4 23709 Electric valve
    6 2371374 Valve blade handle - Moon gray
    8 33342 Fuse - 3 amp
    13 33361 Lip Seal (Post-6/15/00)
    15 33209 Holding tank complete - Moon gray
    17 33210 Automatic vent - Moon gray
    18 33333 Cap & Spout seal
    20 33203 Sliding cover - Moon gray
    21 25810 Measuring cup - Yellow
    [​IMG]
    • Informative Informative x 1
  7. LeeFrancis76
    LeeFrancis76
    Feb 29, 2016
    5
    3
    Weston-Super-Mare
    cool, thanks all. great response, I never thought of any of these, I will have a good look over the next week!
    cheers, you are all super ace!
  8. Mel
    Mel Funster
    Oct 6, 2012
    2,137
    2,158
    De Haan Belgium
    @scotjimland Jim is that the Dometic or the thetford?
    Just that the OP said he had a Dometic.
    • Thanks Thanks x 1
  9. Ginge3685
    Ginge3685 Funster
    Jun 5, 2014
    28
    19
    Plymouth
  10. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    ooops.. yes indeed.. that's the Thetford .. wrong drawing.. doh
    • Thanks Thanks x 1
  11. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,959
    2,880
    Tunbridge Wells
    Bear in mind that the flush will be a lot less powerful and use less water than the one at home
  12. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Remove the one way gate valve. (inline, before the flush pipe into the bowl). On the input side, you will find a small gauze filter, which gets very easily restricted. Remove and cob it out. If the feed is still slow, check to operation of the gate valve, they work on an electro magnet, and can get tired.
  13. buckby
    buckby Read Only Funster
    Sep 6, 2013
    213
    148
    nottinghamshire
    I upgraded to the higher pressure pump and our thetford flushes all the way around the rim now plus the showers better
  14. OwnedbyCollies
    OwnedbyCollies Funster
    Dec 7, 2009
    109
    38
    Macclesfield
    We had the same problem when we first got our van. The flush was a measly trickle and just about managed to get out of the spout. After the initial panic - someone here suggested we ensure the full system is primed. At the time we had not filled the boiler - once we did this and primed the system everything worked fine!
  15. Eeyore
    Eeyore Read Only Funster
    Oct 28, 2010
    370
    414
    Have you checked that the water outlet into the bowl is not scaled up ? Ours does occasionally and this slows the water coming out to a dribble.
    I use half a lemon and rub the cut end round the small outlet pipe on the edge of the bowl and then leave it for a little while. A gently fettle with a toothbrush or cotton bud will then remove the softened scale. White vinegar on a cotton bud will have much the same effect but be slower.
    It's a good idea to wipe the inside of the toilet bowl with the cut lemon too to remove limescale from that. It means that your more substantial productions won't stick to the bowl and need wiping away. We always line the bowl with a thin, one ply paper napkin before such prodctions. Open the trap and it all slides neatly down, wrapped in a paper parcel.
