Body Seal Cleaning
Discussion in 'Motorhome Chat' started by Tincataylor, Mar 5, 2014.
  1. Tincataylor
    Tincataylor Funster
    Jul 9, 2012
    394
    721
    Devon
    I have checked through past threads and not found a specific answer so I apologize if I am bringing up an old subject that has been done to death.
    Having purchased our new toy we have been removing the chalky layer on the gel coat and waxing like things possessed. The result is amazing and the van has come up like new so we are very happy.....BUT....the seals between the body panels are badly stained with black mould and this rather ruins the overall effect. We have found a toothbrush is the best implement for getting in there, but what do you guys use to get rid of the mould?
    ATB
    Tincataylor
  2. williamb
    williamb Read Only Funster
    Apr 28, 2008
    42
    14
    Lancashire
    Cleaning
    Put some white spirit on a cloth and rub over sealant hey presto nice and white. Just dampen cloth do not soak then try a small area. Works for me..... Good luck
  3. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    986
    kent
    caravan wash
  4. icantremember
    icantremember Funster
    Sep 2, 2010
    5,220
    7,312
    Nr Watton in Norfolk
    Neat Fenwicks Motorhome Cleaner and a tooth brush:thumb:
    • Like Like x 1
  5. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,162
    1,249
    norfolk
    Car accessory shops sell brake cleaner, cleaned up my seals a treat, also removes some stains from upholstery.
  6. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    I've been polishing mine today as I need to re seal the overcab and I found the Autoglym resin polish cleaned the old sealant too.
  7. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,812
    1,879
    Warwickshire
    Not related to the question about cleaning seals, but so far as the gel coat on the moulded sections (all of the front and top of the back in my case) I have found Farecla Gel Coat Restorer to be the best solution to maintaining the appearance. I used to use Autoglym Resin Polish all over, but that is now reserved for the aluminium side and back panels - Farecla is much better on gel in my opinion.
    I use the Farecla version with wax included (one job instead of two). It is available from yacht chandlers and was designed for marine application.
    • Like Like x 2
  8. TheDentons
    TheDentons Funster
    Aug 7, 2013
    248
    151
    South Wales
    Where do you buy it
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,353
    9,798
  10. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,827
    5,116
    Guisborough
    Here
    www.ecfibreglasssupplies.co.uk/p-208-farecla-gel-coat-restorer-wax-500-ml.aspx
    I tried to clean our seals up but some were so ingrained that I cut all the old sealant out and applied new job jobbed.
    I second the super resin polish suggestion, neat cleaners and brake cleaners etc will also remove polish so you need to over the joints again anyway.
    Martin
  11. Tincataylor
    Tincataylor Funster
    Jul 9, 2012
    394
    721
    Devon
  12. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,533
    5,620
    Near Mold North Wales
  13. Pat and Trish
    Pat and Trish Funster
    Jun 22, 2012
    376
    649
    New Forest
    Regarding re sealing is there any particular sealant you recommend ?
