Boat on roof ?
Discussion in 'Motorhome Chat' started by Vlad The Impaler, Jul 22, 2012.
  1. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,621
    2,191
    Rutland
    I am looking to buy a small inflatable boat and am thinking of storing it on roof inflated and ready to use.It weighs around the 40 lb mark,what I would like to know is do you buy additional cross bars for it to sit on or does it just sit on the roof and get tied down to the rails that run along each side.
    Thanks steve
  2. philw111
    philw111 Funster
    Mar 22, 2009
    606
    516
    Moray Firth
    Fill it with helium and you can gain some extra payload :Rofl1:
    Sorry, I'm sure some sensible comments will come along soon.
    Phil
  3. hilldweller
    Dec 5, 2008
    27,551
    26,637
    Macclesfield
    40lbs spread out is nothing. Making it secure and paying a bit more fuel is.
  4. emjaiuk
    emjaiuk Funster
    Sep 3, 2009
    124
    85
    Be careful tying down to rails. When we had our first RV we carried canoes on the roof strapped down to the rails, but the sideways pull loosened the rail fixings after a while, causing a leak. Luckily it was an all aluminium Allegro, so no permanent water damage.
    Malcolm
  5. Vlad The Impaler
    Apr 22, 2012
    1,621
    2,191
    Rutland
    God you can tell its Sunday morning:Doh:
    Let's assume I can afford the extra fuel and I use 4 ratchet straps to the side rails,should that suffice! Side rails can't just be for show
    Do I assume you don't get rails to span the width.I suppose would be better on actual roof as less air would get underneath .:Eeek::Eeek:
    • Like it Like it x 1
  6. spannermanwigan
    spannermanwigan Read Only Funster
    May 22, 2008
    394
    207
    wigan, lancs
    The simple answer is dont do it, you will damage the paint on your roof,even the soft material
    of the boat will rub through the paint in no time, this will then lead to the thin aluminium sheet
    oxidising(aluminium equivalent of rust). Pack the boat away and inflate when you need it,which probably wont be that often.
    My advice is to stay off your roof as much as possible and to only go on top to clean it,let it do the job for which it is intended keeping the weather out. not load carrying.
    Maybe not what you want to hear but, but sound advice.
    Look after your van and the van will look after you, thats the secret of succesful ownership.
    regards
    Steve:thumb:
  7. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,999
    9,236
    Wrenthorpe, Wakefield.
    We tie our sevlor kayak up on the roof with straps using the side bars.
    Just make sure you put it upside down then if it rains :Doh::BigGrin:
    We didn't travel to the lakes with it up there , but once there we left it pumped up till we were going home.
    Saved a lot of faffing about.
    PS i thought you were changing your name , to a more man sounding one ?
  8. hilldweller
    Dec 5, 2008
    27,551
    26,637
    Macclesfield
    I think more for show than for serious use. You could read the manual.
    It would be so very easy for "4 ratchet straps" to just bend the rails over, no matter how well made. Most of the force is sideways not down.
    Remember we don't know you, your boat or your van so cannot give valid advice, just hints.
    There is little strength in a wooden framed MH, just enough to keep the box in shape. The rails are probably just screwed into quite small section softwood.
  9. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    why do you want to carry it inflated?
  10. Vlad The Impaler
    Apr 22, 2012
    1,621
    2,191
    Rutland
    Because if it's on the roof inflated its not taking up what storage space we have
  11. rangitira
    rangitira Funster
    Jun 30, 2010
    6,440
    13,416
    Cornwall
    "Fly me to the Moon ,and let me play amongst the stars" comes to mind, tie em loose and they float, tie em to tight and the buffet tears them away.
    You could always take an "inflator" and blow the bleddy thing up when you get there:thumb:
