Blueberries And Greek Yoghurt On The Carpet !
Discussion in 'Motorhome Chat' started by Cobweb, May 31, 2015.
  1. Cobweb
    Cobweb
    Mar 25, 2014
    388
    350
    North Yorkshire
    On our way to Lac DuDer from Nancy we had a really long rough patch of motorway . When going round a roundabout BANG the fridge door opened and contents many contents flew out ! I sprung out of my seat gathered everything and put it back......getting the blame for not shutting it properly . Later at yet another roundabout the very same happened bout the yohurt tub burst as well as the blueberry container and the result was a right mess ! Hubby pulled up to the roadside at earliest opportunity to clear up . Turns out that the catch has got very loose and with the rough road worked it open! Hubby did fiddle about with it and now re assures me that the catch is much tighter ! It is a Dometic ...has this happened to anyone else ?
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,430
    6,028
    St. Helens MERSEYSIDE
    Yes Many Times I ended up putting a pop rivet in the hole at the opposite side to the hinges as the repair kit for the door lock is about £12 and a waste of time as the locking mechanism is crap imho,this has not failed me yet .:)
  3. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Again many.... many times!:)
    But no mess thankfully...door lock fine just forget to use it. Same goes for drawers....I'll get the hang of this eventually!lol
  4. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,694
    3,216
    East london
    We forget to lock it about 20% of the time.. Been lucky so farfar.. no mess.
  5. trophychap
    trophychap Funster
    Dec 24, 2009
    731
    5,779
    bedworth warks
    We have touch wood never had that problem occur. However the cupboard opposite the fridge frequently gets the lock off, and I will be negotiating a roundabout or some such obstacle and there will be an almighty clattering as the stainless steel steamer pans make a bid for freedom across the back of the van.
    I have got used to it now but at first it was very disconcerting, surprisingly enough they have never suffered any dents.
  6. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,951
    8,043
    Paignton, Devon.
    For any yoghurt residue on the carpet, try soaking it up with talcum powder or salt might work if no talc.
    A steamer on it when you get home should get anything out.
    • Like it Like it x 1
  7. themogs
    themogs Funster
    Oct 23, 2012
    860
    908
    Wales
    Sounds a good mix for dessert :whistle::whistle:
    Blueberries & Yogurt...yum, yum (y)(y)
  8. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,833
    8,964
    NW England
    No trip would be complete without our Dometic fridge puking its contents on the floor during a tight turn.
    The door height is adjustable (after a fashion) by fiddling with the size of washer on the bottom hinge, after unscrewing the top hinge and lifting the door off. It might be that it's hanging too low to lock properly, or too high to lock tightly.
    • Like it Like it x 2
  9. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,032
    13,895
    Bolsover, Derbyshire
    We (I) broke two of the weedy plastic slide catches, replaced them both at about £12 each as said, then at a service (Hambiltons Preston) they noticed the catch was out of alignment sorted it fitted a third catch been perfect since.
    What I had noticed was that when I broke the plastic slide and removed it, the actual lock is metal, I was able to push this over with a screwdriver and it never came open. Probably should have just left it like that :)
  10. Judge Mental
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    daughter and wife's fav brekie in a rush these days is: porridge mixed with yogurt and frozen summer fruits or blueberries. left in fridge overnight ..eaten cold in the morning. its a bit cold for me..prefer my porridge warm:)
  11. parknride
    parknride Read Only Funster
    Jan 21, 2014
    2,111
    4,852
    cumbria
    Hijack here, do you mean the site near St dizier? If so can you recommend it? Looking for our next stop going north. Thanks.
  12. Cobweb
    Cobweb
    Mar 25, 2014
    388
    350
    North Yorkshire
    Hi . Yes there are several Aires around the Lac Du Der the one we stayed in is in Giffamont Champaubert and was free . If you are into cycling there are several bike tracks around the lake . The forecast is not great tomorrow but gets hotter on Tuesday ,in fact it looks like a bit of a heatwave is on its way here . By the way the fridge contents have stayed put so husbands fiddling must have helped.
  13. parknride
    Jan 21, 2014
    2,111
    4,852
    cumbria
    @Cobweb Thanks, we are at langres going on the camper stop tomorrow to visit the town then Tues coming up that way. Looking at the acsi site with pool to cool off in. Forecast looks great from Tuesday:cool:. Then maybe Verdun for few days.
    Glad your fridge is fixed, looks like you are going to need it!
  14. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,767
    10,178
    fridge door and contents on the floor go hand in hand with motorhomes. in fact I have heard of a few fridge doors falling off completely on rough journeys
    as for getting yoghurt out of carpets, I find the dogs take care of the worst and a coating with talc left to dry before hoovering helps a lot. then steam clean at the earliest opportunity to kill bacteria
  15. parknride
    Jan 21, 2014
    2,111
    4,852
    cumbria
    BTW, we went to visit friends in Denia, they live up top of a mountain. They said oh its quiet no big traffic in February you'll be fine. We filled the fridge after a big supermarket shop then set off up the mountain. First hairpin bend, bang, everything out. OK pull up, have a row who's fault is it, sort it set off. Almost up the mountain down comes a cement mixer!! Les just kept cool and reversed until we could pass. I was under the dashboard saying my prayers. Had a lovely time when we got there though.
  16. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,958
    12,241
    Plympton, Devon
    And here was me thinking from the title you were have a wild frolic on the floor! :)
  17. Cobweb
    Cobweb
    Mar 25, 2014
    388
    350
    North Yorkshire
    Hi . Have you tried Langres cheese ? It tastes a lot better than it smells . We are heading south towards Limousin and the Dordogne
    Next stop campsite South of Auxerre to catch up with laundry and other chores if the weather is a bit iffy tomorrow . We are in a nice riverside aire Gurgy with hookup and we think that we have blown the EHU by plugging our kettle in ! Nothing works on the EHU the trip switches or the main switch ! The thing is that at least 5 other vans have lost their power as well ! I feel like hiding seeing everyone fiddling around with it ! Hopefully someone will come and fix it . All the fault of bloody Rostbeef with their electric kettle! The joys of motorhoming !
  18. parknride
    Jan 21, 2014
    2,111
    4,852
    cumbria
    Keep schtum! Will:whistle: (might) smell/ try the langres cheese tomorrow. Have a great trip, love the dordogne(y)
