blue smoke on tickover (1 Viewer)
cypsela
13
3
morecambe
fiat ducato 1996 hobby
im a newbie
hi bought a fiat ducto 1.9td 1996 model two weeks ago new to motorhomes quite high mileage,was ok at first,getting quite a lot of blue smoke in traffic and tickover,does anyone have any ideas,my garage say it is valve stem oil seals,which they are replaceing,is this common for these vehicles,any advice would be appreciated,
43,329
49,444
A clogged air filter can cause blue smoke.
Plus, You normally get a lot of smoke under acceleration after periods of light loads if the cylinder bores/oil control rings are worn.
Cant be too bad or it would have failed the MOT visible smoke test.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Mine does it all the time, not so much blue, but overfueling smoke. Gets better as the engine warms up. Always comes in OK with the MOT though.
C
cypsela
13
3
morecambe
im a newbie
hopefully valve stem oils seals will do it,it came all the way from sommerset to lancashire no problems,put it down to newness issuses,
TheBig1
17,630
43,277
change the oil first along with oil and air filters and see if that helps. the same symptoms with a dirty, carboned up engine
