Bloomin' Electric Circuits
Discussion in 'Tech/Mech General' started by dickymint, Jun 2, 2013.
  1. dickymint
    dickymint Read Only Funster
    Jun 2, 2013
    4
    Cornwall
    Any budding sparkies out there who can advise. We have an old Machzone MH. Super vehicle but there now is a problem with the electrics which I cannot trace the fault. 12V circuit off leisure battery and mains 240Vconnection works fine except off both power supplies the toilet flush, water boiler ignition and gas fire up for fridge do not work. Light circuit and sockets all fine. System is powered with Logic 1 and Zig board. All fuses are fine unless there are fuses I don't know about. checked 25A x3 in Logic 1, 10A & 5A in Zig. All ok.
    Am I missing a distribution board of some sort? I cannot locate one or would the problem run on an independant circuit? Appreciate any help:cry:
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Whereabouts in Cornwall are you?
  3. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,701
    1,501
    West Midlands
    I didn't know electrical systems were so tempramental. Does he need to move to another part of Cornwall?:Rofl1:
    Wyn
    • Like it Like it x 3
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    How long have you had it.
    When did it stop working,
    is there power at the Zig unit
    are the switches in the right positions.
    What voltage does the leisure battery read
    what does it read with the engine running
    do you have solar power, who installed it.
  5. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    tis all those furineers messing wiv the vironment init
    • Like it Like it x 2
  6. rainbow chasers
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Oh Yes! There are strange goings on in these parts......in certain areas, them piskies play round with your lectrics iner?
    Nah! seriously - if he is near enough, may as well have a look as it would be quicker than explaining. Doesn't appear to be too complicated from the sounds of it.
    Mind you.....how many times has a 5 minute job lasted a bit longer!:Rofl1:
  7. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,937
    10,302
    sounds like a fuse or loose wire to be honest
    The time searching for the fault would be expensive if you went to an auto electrician, and they would probably end up just running a new fused feed and connect to the circuit
  8. dickymint
    Jun 2, 2013
    4
    Cornwall
    Very good, I thought I might get some stick !! I said budding sparkies not the Britains Got Talent roadshow :BigGrin:. In answer to some replies, we are in Lanson. Had MH for a couple of years. There is power to Zig board but I can't tell you how many amps the battery is pulling, no solar panels fitted.
    Look forward to your replies :Smile:
  9. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    ok so there is power going in the zig board is there any coming out, and I believe I asked for voltage levels not amps. If you cannot read the volts how do you know what power there is where. Have you got a multimeter and do you know how to use it. Fault finding requires taking readings. A bit of banter is normal don't let it upset you it does not stop you getting replies it just keeps the thread alive.
    • Like it Like it x 1
  10. dickymint
    Jun 2, 2013
    4
    Cornwall
    I don't mind the banter at all Wildman. Its all in good fun. I havent got a meter but i have pulled the fuse out of the zig board when the lights and water pump were running and they stopped. I have had a look at the wiring in the zig and it looks a mess. 2 red wires (one linking live to different fuse? not connected) and one just not connected to anything. Some historic soldering gone on at some stage looking dodgy too. Think a good starting point may be to replace this first. What do you think?
    :Doh:Cheers Dickymint
  11. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    It sounds well messed about and I'm afraid advising you won't help, I suggest rainbowchasers offer of help is taken up even if it means you driving across Cornwall to meet him.
    To sort out electrics takes patience and understanding, if you had the required knowledge I'm sure you would have a meter. It May be worth looking at the 12V seminar in Ilfracombe in August that would help you with some basic theory and some practice in using a meter.
  12. rainbow chasers
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Lanson not too far, if you need help give me a shout, I can pop up and take a look and sort it out.
  13. dickymint
    Jun 2, 2013
    4
    Cornwall
    Many thanks Rainbow chasers. It would be only right and proper for me to come to you. I would not be free until an evening next week. If this is ok let me know where and when. Once again many thanks:BigGrin:
