Blocked windscreen washers 2011 Fiat x250
Discussion in 'Motorhome Chat' started by PhilandMena, Feb 18, 2016.
  1. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    Hi,
    My windscreen washers are blocked with dust/sand and I have tried to clear them with a needle but without success.
    Does anybody know for certain how to free then, I am unable to get access from underneath and I suspect they may prise off from the above but not sure.
    Thanks in advance.
  2. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
    If you can get a can of compressed air and take of the pipe feeding the jets and blow in normal direction as sometimes using needle forces sand and dirt into tube. Even a normal air compressor might work. You may find there is also crap in the bottle so washing that out will stop the stuff traveling back up the tube and reblocking it.
  3. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    Unable to get at the pipe feeding the washers as it's behind the scuttle.
  4. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Bugger
  5. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    Check the water bottle first, there is often a filter in the bottom. Then use an air line all the way from the bottle, not to much pressure though.
  6. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    Problem resolved, thanks to one and all. traced tube from bottle and found union joint and managed to blow through clearing both washers.
    • Like Like x 5
  7. Irishrover
    Irishrover Read Only Funster
    Oct 20, 2014
    423
    2,176
    Wicklow Town, Ireland
    Thats good to know...need to do mine.
