Blocked waste
Discussion in 'Motorhome Chat' started by Jerrymjj, Jun 15, 2014.
  1. Jerrymjj
    Jerrymjj Funster
    Apr 3, 2014
    90
    27
    Alton Hants
    Sat on a campsite in Kent watching the contents of the sink going nowhere. Waste tank gauge telling me tank is 100% full (fully emptied before we left home) but just a dribble coming out of the vent pipe if I open the valve. Clearly something is blocked somewhere. Can't really start dismantling it here so can anyone advise me of something safe to pour down the sink once it has lost enough water to let me add something? Are the domestic pipecleaners safe enough to use? Many thanks, Jerry
  2. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,096
    6,655
    Spain for the winter
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,075
    2,920
    Kendal, Cumbria
    If you can find an empty plastic bottle (milk maybe) with a top that fits your sink drain you can use it like a plunger: press it firmly into or over the sink outlet then squeeze hard. It needs to be a decent seal to the sink outlet but it always works for me. You can do the same with the tank outlet - open drain push bottle against it & squeeze. Move bottle (and yourself!) away quickly.
  4. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Try 2 Ltr Bottle of full fat cheap coke it clears your tank out might do the same for your pipework. Pete
  5. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,718
    8,809
    NW England
    I had this problem with the sink at home, and no amount of so-called Mr Muscle drain cleaner would shift it so for about £4 I bought one of those converted 3 metre curtain wire thingies with a winding handle on the end, cut the useless stretched spring bit off the end and shoved it down the pipe after the u-bend as far as it would go, then jiggled it about. That loosened it up, and after a good flush of water and detergent the blockage is gone. For now.
    • Like Like x 1
  6. Styx
    Styx Read Only Funster
    May 1, 2010
    572
    2,970
    Buckinghamshire
    Still some in the local Aldi when I was there this morning
    https://www.aldi.co.uk/en/specialbu...uk_product_newsletter&pk_kwd=2014-06-09_14-30
  7. Dawn B
    Dawn B Funster
    Oct 20, 2013
    5,220
    14,666
    South Norfolk
    Ex-lax
  8. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    You need to work out if it is the tank not emptying (hence the 100% reading), or it is the pipework from the sink to the tank.
  9. Jerrymjj
    Jerrymjj Funster
    Apr 3, 2014
    90
    27
    Alton Hants
    Now home so hope to investigate properly. Bought and administered some disinfectant scented drain unblocker and then drove home to no effect. As very little comes out of the waste when valve is opened I assume the blockage is at the tank end but unfortunately the vent pipe goes through a right angle as it enters the tank and I can't get my drain unblocker wobbly wire to go into it from the end of the waste vent pipe. Going to cut it tomorrow and stick something in to try and unblock it. Have already tried blasting it with the garden hose stuck up it. Whatever it is, is tough!
  10. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,190
    Rutland
    The same thing happened to me a couple of years ago,I tried wire ,hose etc with no joy.In the end I took off the 45 degree bend with the tap on and went to a garage with a pressure washer type car wash,shoved it right up the pipe,gave it a couple of pulses and the blockage cleared.
    It blocked again a week later so I did it again,each time there was a slimy placenta like waste left after the tank had emptied,so I figured that the tank had never been cleaned in its life.I bought a tub of caustic soda mixed it in a watering can,poured it down the 2 sinks and shower and went for a drive!
    When I got back I opened the tap and :Eeek: it was like a scene from Alien meets Ghostbusters,a strange gooey gunk that stunk like hell.Never had a problem since and still get no weeds on that part of the drive!:RollEyes:
    Vlad
  11. Jerrymjj
    Jerrymjj Funster
    Apr 3, 2014
    90
    27
    Alton Hants
    Latest...
    Shoved all kinds of things up it but not much progress, finally got a bendy pipe thingy into the tank but had a terrible job getting it back out which suggests there is something in the outlet. No waste material on the probe when I go it back out. Shoved the garden hose up it and the water obviously got through as it came back out again. Now put some nasty chemical in it and leaving it overnight to assess results. If all else fails I guess I'll have to drop the tank but even then (it is a plastic thing) I wonder if there will be any access hatch. I doubt it...
  12. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,117
    3,525
    walthamstow east london
    if you have put drain unblocker down it be very careful it will take the skin of your hands and i dread to think what it could do to your eyes
    im a plumber by trade , ive asked people if they have put any acid down and been told no only to find my hands melting the second i open a pipe
