Blocked sink drainage (1 Viewer)
Southampton
522
318
Hampshire
Since 2009
We are sat on Wykes Farm site at Andover for Easter and the kitchen sink is blocked. I can get it to drain very slowly by agitating it with a plunger but clearly something is blocking it. The shower and toilet sink drain okay. The question is, can I use Mr Muscle or some other drain cleaner without damaging any of the pipes? Or any other suggestions welcome.
Derek
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if you look under the sink there may be a smell trap with a unscrew-able bottom.
Southampton
Southampton
522
318
Hampshire
Since 2009
Thanks Andy, could not see anything under the sink the pipe disappears behind the cooker. I will see if I can see anything from underneath the van in the morning.
43,329
49,442
as already said, there may be a small round trap in the waste pipework underneath the van floor in the external pipework to the grey tank.
usually about the size of an old KIWI boot polish tin but a little thicker with the waste pipe entering and exiting on opposite sides.
unscrew the bottom (if it is blocked you may get a sudden gush of water :whatthe:) and check its clear.
try boiling water first as its probably grease/fat which has congealed in the waste.
Mr Muscle etc should be ok but dont get any on the sink surface.....it could stain.
use a toilet roll tube etc as a funnel to direct the liquid straight into the waste pipe.....SLOWLY, so as not to overfill the 'funnel'
philk
173
50
Lancs
since 2000
Blocked sink
Every time my sink has gone slow its been congealed fat, I use hot water and fairy liquid and slowly it goes through.
Phil
Southampton
Southampton
522
318
Hampshire
Since 2009
Thanks everyone, now pouring hot water and fairy liquid to see if that works, it is draining but very very slowly. I am guessing that it is more likely to be blocked with a combination of rice and fat as we have had curry on Thursday and it was fine before that. Anyway, next step is to get underneath and see what can be done.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
When either of our sinks start to drain slowly we have found that Thetford Grey Tank Freshener sorts it out.
Mike.
I also forgot to mention that,over the 2 yrs period we have been using it,the black coating on the inside of our grey waste tank has completely gone.::bigsmile:
Mike.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You will probably need to clean the waste traps beneath as papaohn suggests. they will fill with lots of crud.
A cheap drain cleaner will work fine. We have used a 'keep it handy' drain cleaner (99p) which does the job a treat, poure a little down, wait 20 mins and rinse with hot water. Do not throw the waste down the elsan point if on site though, as it may have issues in their slurry tanks. (or at least ask)
