Blocked bathroom sink (1 Viewer)
Tessntim
58
7
Devon
Fiat ducato
My sink is blocked Iv tried sink unblocker hot water and a long pipe but still can't unblock it any ideas folks
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
There are plenty of stuff thats available from B&Q for unblocking drains and sinks, i use one regular on the sink at work, its in a yellow bottle and costs around a fiver - pour a quarter of the bottle down the sink/plug hole and leave over night - always does the job
Tessntim
Tessntim
58
7
Devon
Fiat ducato
This won't rot these pipes will as the obviously not the same as house pipes
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
Has this just started to happen or has it always been there.?
Try pouring some bicarb down the sink and then pour some vinegar in on top of it. It fizzes like mad but usually cleans it.
Periodically pour some loo fliud down the sink to keep it smelling "*** lovely **
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
Try some net curtain wire, it will follow any bends but is rigid enough to break up the blockage or, use a dingy pump or similar, seal into the sink waste with a rubber glove and pump, it will clear the blockage or blow the pipe joints apart!
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds like the pipe may have collapsed, disconnect from the tank and check it straight. From one side of the van to the other is very little drop so it does block easily, have you tried a sink plunger.
