bleeding water pump
Discussion in 'Motorhome Chat' started by Soccer12, Jul 16, 2008.
  1. Soccer12
    Soccer12 Deleted User
    dont want to burn out the pump, how long should it take to get water in the lines and to the faucets. Teh pump hasn't been used before.
  2. itexuk
    itexuk Read Only Funster
    Apr 3, 2008
    74
    Taunton Somerset
    Depends on how big your hot water tank is as that has to fill but about 60 to 120 seconds
    Make sure there is plenty of water in the fresh water tank.
    Turn on pump electrics.
    Pump should start to run
    Turn cold kitchen tap on low, after a few seconds air and water will start to come out. Let the water run until all air is out of system.
    Do the same with all other taps and then do the same for the hot.
  3. Soccer12
    thanks
    I am doing that for several minutes without any results.
    could it take longer? am I at risk of damaging the pump?
    Keith
  4. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Is the pump 'self-priming'? If not, you probably won't get water through it without priming it first.
  5. Thepips
    Thepips Trade Member
    Sep 26, 2007
    500
    Basingstoke
    Yes, you are in danger of burning the pump out. You shouldn't run it dry for more than 10-15 seconds. On our RV water is at the taps within seconds.
    It sounds as though the pump isn't priming, they'll will suck air rather than water if at all possible.
    The causes I can think off
    1. The intake pipe may have come adrift
    2. Intake pipe may have even collapsed
    3. Membrane has a hole in it
    4. Shaft snapped
    If it's possible I'd pull the outlet pipe off the pump and try again. If it's not pumping uphill it may be able to start pumping. At least you'd know if the pump was working or not!
    Without knowing the vehicle it's a little difficult to diagnose but as you said faucet I'm guessing American.
    Regards
    Doug
  6. Soccer12
    American is correct, 2000 Winnebago Adventurer. The pump has never been used I wonder if it is possibly a seal or something.
    Keith
  7. Thepips
    Sep 26, 2007
    500
    Basingstoke
    On my last motorhome the pump had a rubber membrane which had split so it didn't pump. Unfortunately the pump was damaged by water being on the wrong side of the membrane and I had to buy a new one anyway.
    Regards
    Doug
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    East Sussex 01-580-881288
    Hi, disconnect the outlet pipe and see if it pumps water out, (have some one handy to turn pump off if it does!)
    If it does'nt, more than likely rubber membrane has split, fairly easy to replace if you can get spares. Lindy C might know.
    If not buy a Fiamma Aqua 8 pump, good pump and spares available if ever needed.
    See our website and search Fiamma products if you want one.
    REgards
