bleeding injectors help please :helpsos: (1 Viewer)
Nov 18, 2011
11,862
42,914
Planet Earth
A van
Over 25 year's
hi i am having problems bleeding the injector after an engine rebuild any help appreciated thanks
bill:helpsos:
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Probably cannot help you as only ever had to bleed old tractors but we used to crack open the pipes at the pump and crank it over and then un do each injector pipe in turn and crank it again until it fired up-----This info is probably 30 years behind times
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Be careful I have a friend who has hardly any sight in one eye now doing just that:Eeek:
wasp
1,724
18,180
Warsop
None gone caravannin
There is usually a lever on the pump to push the diesel thru to the injectors after you slacken off the pipes one by one:Smile::Smile::Smile:
Wildbill
Nov 18, 2011
11,862
42,914
Planet Earth
A van
Over 25 year's
thanks that's wat i have been doing but it seems the pump not getting fuel never had problem like i have had with this
thank for posting :thumb:
wasp
1,724
18,180
Warsop
There should be a bleed screw on it some where
Wildbill
Nov 18, 2011
11,862
42,914
Planet Earth
A van
Over 25 year's
i have done all that cant under stand it something wrong and cant put my finger on it seen to have me beet at the moment:cry:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Bill is there a small bleed screw on the top of the pump? If so bleed by unscrewing a little and turn over while priming to bleed the pump then do the injectors if it will not start you could try easystart to just start it a couple of times and pull the fuel through
Wildbill
Nov 18, 2011
11,862
42,914
Planet Earth
A van
Over 25 year's
it's a brand new engine almost won hurt it will it
43,321
49,408
easystart is a useful tool in very slight moderation....but then, like a drug user, it becomes addictive and essential.
sounds to me like you have an air leak (not lock) on the filter head.
combined injector/lift pump will draw fuel from the tank...unless it can draw air easier.
wont show as a fuel leak as the lift pump causes a vacuum on the filter sucking fuel through (or air)
Steve and Denise
5,287
14,081
Spalding LINCS
A Class Carthago
Since 2008
Pump
Firstly you must make sure you have fuel to the pump ie the bleed screw on the pump once you have fuel at the pump only then you can expect to see fuel at the injector pipe nuts when cranking the engine. If no luck check the fuel shut off solenoid on the pump some times the plunger can stick in the off position you can remove this to test if it is working with little effort.
