Black water dump points - is there a register? (1 Viewer)
Peter_n_Margaret
86
62
Adelaide, Australia
"C" class 4WD DIY
About 20 years
How do we find public black water (toilet) dumping points as we cruise the UK & Ireland?
Is there a register/list available somewhere?
We hope to be mostly wild camping where we can.
In Australia, the public dump points are all listed here.......
Broken Link Removed
Cheers,
Peter
icantremember
8,328
17,540
Near to Watton in Norfolk
Hymer T-SL668
since 2005
No chance .... this is the UK where they don't make life easy for wild camping and most towns don't like motorhomes.
Having said that, most camp sites will allow , for a charge, you to empty as necessarry and fill as well.
Good luck and enjoy your trip.
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
Do you need a black water drain point for a tank or just a toilet you can empty your cassette into?
Toilets are easy to find, tank dumps less so.
Puddleduck
12,378
43,951
Scottish Borders
Without at present
On and off for many years.
Shhhh... don't tell as I'm sure you shouldn't really do this but you can empty your cassette down a public loo but make sure you take disinfectant and cloths to clean up after you. If you leave everything cleaner than you found it there should be no complaints.
jb0371old
465
408
Norfolk
Autotrail
1 year
while the missis shops in the supermarket, I generally take the cassette (inside a day sack and plastic bag) to the loo and dump it. Or caravan sites generally let you fill up and drop off sometimes free but generally for a price.
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
In Scotland you will find a free to use dump point at most if not all CalMac ferry terminals, (Caledonian MacBrayne) they are mostly small harbours with free access to all. We have found that most, especially out on the islands have a water point and dump
Please note though, nobody should put standard elsan chemical down any toilet, it is seriously harmful to the sewage treatment process even in small doses. If dumping straight to toilet or random manhole you should not use chemical
http://www.visitouterhebrides.co.uk/visitor-info/facilities/toilets-and-portable-toilet-disposal
just found this link for western isles, it is only going to help for a very small part of the UK, but every little helps
jb0371old
465
408
Norfolk
Autotrail
1 year
we dont use that blue stuff. Bio liquid from the supermarket cheaper easier and makes it easier to dump anywhere
Puddleduck
12,378
43,951
Scottish Borders
Without at present
Sorry, I should have put that on my post. Being on septic tank at home the use of chemical stuff that isn't okay for septics is a closed book to me and I tend to forget that people use elsan and other such chemicals in their cassettes.
Peter_n_Margaret
Peter_n_Margaret
86
62
Adelaide, Australia
"C" class 4WD DIY
About 20 years
Thanks for the tips folks.
Looks like it will be a bit harder than I anticipated.
Sodium Percarbonate is the best stuff for toilets. Typically sold as nappy soaker. It is cheap, effective and safe for septic systems and all toilets.
Cheers,
Peter
Puddleduck
12,378
43,951
Scottish Borders
Without at present
Peter
AKA Nappysan in the UK although supermarkets may have their own brand. It's also great as an additive to the white laundry load.
I'm told you can also use bio-washing detergent to the cassette. I imagine it would smell much better than the formaldehyde type stuff beloved of tuggers.
Jan 31, 2009
493
472
Shropshire
Van Conversion
10 years +
" nobody should put standard elsan chemical down any toilet, it is seriously harmful to the sewage treatment process even in small doses."
What I've never understood is where all the stuff with chemicals that goes into CD points at a campsite go to. Do they have a separate drainage system for the CD point that doesn't meet up with their normal sewage? If so, where does it go?
PS I use Aldi detergent.
GJH
29,450
38,827
None, now sold
2006 to 2022
(snip)
Please note though, nobody should put standard elsan chemical down any toilet, it is seriously harmful to the sewage treatment process even in small doses. If dumping straight to toilet or random manhole you should not use chemical(snip)
I tried Googling to find a reason for that but couldn't. Obviously cassette contents (amongst other things) should not be emptied into an ordinary drain (whether meant for grey water or surface water) but surely the final destination of the flushings (including bleach and all sorts of cleaning products) from a WC is designed to deal with such chemicals isn't it?
