Black smoke (1 Viewer)
Sep 8, 2010
729
1,264
Kent the white cliffs end
LeVoyageur Lvx 8
Not long enough
Took van out the other day and noticed a lot of black smoke coming from the exhaust so today went for a hard run to see if it would clear ,but no so have booked into garage today I hope it's not to bad:cry:
43,320
49,406
Black smoke = unburnt fuel.
blocked air filter/collapsed hose/damaged (poor spray pattern) injector.
air hoses can de-laminate and collapse internally with no/little outward signs
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
turbos normally start to whistle as they spin up under engine load.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if the van has been laid up for a while it could be a rodent nest in the air box i have seen this on occasions before.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Knackered EGR valve?
Dead rat in your air intake?
Detached turbo/ intercooler/ inlet manifold hose?
Stuck turbo wastegate actuator?
There could be many causes, but black smoke is sooty, inefficient combustion caused by excess fuel or too little air!:Sad:
Injector problems tend to lead to white smoke caused by unburnt fuel due to poor atomisation of the diesel in the cylinders.
Hope this helps and good luck at the garage!:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I think a blown turbo is thick White smoke:whatthe:
Engine oil in the exhaust due to blown turbo seals is exclusively blue! And it really smells!:cry:
shunter
Sep 8, 2010
729
1,264
LeVoyageur Lvx 8
Not long enough
Well thanks all for your replies, the garage will find the problem i hope thay are allso going to change the oil and filter for me:thumb:
