Black out roof blind
Discussion in 'Motorhome Accessories' started by The Spongebobs, Aug 14, 2016.
  1. The Spongebobs
    The Spongebobs Funster
    Aug 29, 2015
    69
    15
    Oban, Argyll and Bute, UK
    The black out roof blind in our Hymer is broken. It will put across but it takes for ages to open it again. I have had a quote for a new unit as over £500. Any cheaper ideas please
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,940
    A photo and details of the roof light (Heki?) would help.
    If it is spring loaded you may be able to re-tension the spring
    If not you should be able to buy a spare and fit it yourself for far less.
  3. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    If you get no luck with a replacement you could try my remedy, our Hymer has never had one fitted and I have never been able to find one to fit myself.
    When the wife got fed up with 04.30 starts due to raging sunlight I got a piece of card cut from a box and glued the radiator reflector foil to both sides (thin layer of polystyrene with foil glued to it).
    Each night I wind up the roof vent a bit, slide in the home made blind and wind it down to trap it in place.
    Foil both sides means it doesn't matter which way round you fit it, and it keeps the van cooler if you fit it on hot days as well.
    Foil from Lidl, £1.29, PVA glue from the pound shop, 99pand card from an old stair gate box, free.
    It's been working well for over 2 years so far.
    Hymie.
    • Like Like x 4
