bio deisel
Discussion in 'Motorhome Chat' started by Bruce, Oct 31, 2012.
  1. Bruce
    Bruce Funster
    Aug 12, 2012
    147
    51
    Glasgow
    Hi has anybody any ideas about biodeisel fuel and can you mix with regular deisel.................Bruce
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,227
    16,812
    Liverpool.
    Have been running on it for years and many thousands of miles with no problems whatsoever. It depends on what engine you are using it in whether its suitable or not. I suggest you do your homework on this. As for mixing it with diesel, it will mix in any quantity.
    Try to stay clear of Lucas injector pumps, unless you fit an inline heater.
  3. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    bio diesel
    All diesel sold in the UK has bio-diesel mixed with petro chemical diesel.
  4. Snowbird
    Apr 24, 2009
    10,227
    16,812
    Liverpool.
    Very true and I believe they are about to increase the amount of bio soon.
  5. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    and probably increase the price once again :cry::cry::cry:
    • Like Like x 1
  6. Leftlegger
    Leftlegger Funster
    Sep 29, 2012
    418
    401
    N.somerset
    Agree with both previous posts,Older engines are probably safer to use bio,but again,do your homework,bio affects rubber and other seals so be careful,morrisons may have 5% added at the pumps as already said,also bio is much the same price at the pumps but you,re allowed to make 2500 litres withought paying tax.Personally i,ve got a friendly local club who let me have their old WVO,i filter it 2 or 3 or 4 times to 1 micron,then mix it 50/50 straight into the camper,1994 1926cc fiat ducatto base,I,ve done spain and back on it no problem,got caught out once when i left it settling and didn,t notice the sediment that collects over time.Always carry a spare fuel filter.Dont think i,d try it on more modern engines with engine management and the like,but some are made for it ,so i,m told.:Smile:
    It does smell like your local chippie though:BigGrin:
    • Like Like x 2
  7. Snowbird
    Apr 24, 2009
    10,227
    16,812
    Liverpool.
    To give you some idea of running costs, I have just returned from a 1000km round trip with a 5 ton MH towing a boat on a trailer for 75% of the journey for the princely sum of £50. I do have long range tanks fitted though :Cool:
    • Like Like x 2
  8. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,423
    25,444
    Planet Zog
    The latest EN590 spec for diesel allows for up to 7% bio product which is more correctly described as FAME. Loads of references on the internerd but here is one I pulled down from a trader's website http://www.mabanaft.co.uk/Mabanaft/images/pdf/prodspec-Diesel.pdf
    That does not mean to say that there is 7% in there - it is a max spec and as it is expensive there is probably less. It is rather a good lubricant so helps in ultra low sulphur diesel as the sulphur is a lubricant, believe it or not.........
    There is a lot of stuff written on motorhome forums and elsewhere about putting "bio products" into their fuel tanks and well worth a look if you are bored. Anyone that sticks the stuff in a modern common common rail engine other than according to the specification is taking a risk, though it works well in older engines. It can destroy seals and pure FAME does not have great cold properties. In a harsh environment, it can also oxidise and additionally deteriorate due to anerobic bacteria causing filter blockages..
  9. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,190
    Rutland
    On the subject of diesel does anyone know if running a vehicle on red diesel would do it any harm.Obviously it's illegal but what would be the risks.
  10. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,594
    22,679
    Narrfoook
    have run on filtered and doctored chip oil in my 2007 2.8 Peugeot without any issues at all
    • Like Like x 1
  11. Gooney
    Gooney Funster
    Jun 2, 2010
    4,766
    7,853
    Flintshire
    A big fine?:RollEyes:
  12. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    red is just the same stuff but has a dye and a chemical added.
    mechanically there is no difference but if the powers that be caught you its a hefty fine and vehicle can get crushed.
    • Like Like x 1
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,556
    YO11 2BD
    red diesel is exactly the same as road diesel but a red dye is added to denote a different tax rate has been paid....5% i believe, the same as domestic heating oil..
    get caught with red in yer tank and you may as well say goodbye to your motorhome and your wallet.
    you cannot remove the dye and it lingers for a very long time so filling with regular diesel again will still show a red dye.
  14. WAG2CRU
    WAG2CRU Read Only Funster
    May 31, 2012
    378
    496
    Argyll
    You will also find that Marine Red diesel can be significantly more expensive than white road diesel unless you are buying it in large quantities. Marine supplied diesel for use at sea does not contain FAIM as, it can damage the seals in the fuel pumps of older engines and over time encourages the growth of "Diesel Bug". This should be taken into account for those who winterise their motor homes, it was always the case that filling the tank before laying up was advised to reduce condensation however storing quantities of fuel for months can now have much more damaging consequences. The use of soltron or a similar product before winterising may be advisable.
  15. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    You will find that it is only the older engines with Bosch pumps that will handle it, as these are more agricultural for want of a better term. Any other pump will suffer.
    The mixture would need to be correct, too neat and you have problems with reliability - I had a guy in a landrover who was a 'regular' for breakdowns years ago. I would recover him and take him to garages - it got to the stage where every garage would not accept his vehicle as he had been running neat bio.
    In colder climates, you need a pre-heater - in a motorhome, laid up for months you would need to drain the tank or pop in a percentage of petrol to deal with mould. Is it worth it? Not really!
  16. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,707
    1,315
    living the dream.
    Not that we use it but I saw a program a few weeks ago that says to use bread to filter diesel to take the dye out,take a lot of bread though to sieve a few litres of diesel... dont shoot the messenger I just saw it on tv???
    • Like Like x 2
  17. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    It can be removed if you know how - I did see a program where they raided a workshop in the midlands that were doing just that. There were huge containers of 'white' diesel that had been treated and barrel upon barrel of red waiting.
    What they had been adding/doing to process it they didn't say - for obvious reasons! Though I would imagine the average chemistry teacher could tell you.
  18. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    Biodiesl
    I run my 1999 P38 Range Rover DHSE on straight home made bio also ran my landrover discovery on it with no problem. As someone has said in a previous post I always carry a spare fuel filter in case of gelling. I add Bioboost to give a bit more power and Wynns Fuel Biocide to prevent diesel bug. I will also be running my motorhome on biodiesel when I get it.
  19. Snowbird
    Apr 24, 2009
    10,227
    16,812
    Liverpool.
    There are a lot of misconceptions regarding bio diesel. The main one is that bio diesel is NOT filtered cooking oil. Properly made bio fuel will run in almost any diesel engine. Its who makes it that matters. Quality is the word with bio. The likes of McDonalds and many bus companies would not risk breakdowns with sub standard bio. If its made correctly its OK in ANY vehicle 100%, the problem is that Joe Public thinks he can nip round to the nearest chippy and tip the contents of the fryer into his tank after sieving through a pair of his wife's tights. Have a look at "Journey to Forever" if you want the real lowdown and stop listening to people that have tried straight veg with disastrous results. I have a VW golf with well over 150000 miles on the clock that has never had diesel in it from new. Theres more conflicting reports on bio diesel than Aframes and gassing put together. Do your homework properly and then you will know the TRUE facts.
  20. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    This is absolutely correct.
    I have been making biodiesel for about 5 years and not had any problems. I attended a course before I started at the low impact living institute in Buckinghamshire mainly to get the lowdown on the personal safety angle, methanol and caustic are dangerous chemicals!.
    These days the biggest problem is getting hold of the waste oil with sourcing the chemicals a close second.
    A good resource for bio fuels is here
    If anyone near me in Weymouth, Dorset would like to see the process or just have a chat send me a pm.
    • Like Like x 1
Similar Threads
  1. wingman
    47
    2,066
