Bike rack on door or tow ball? (1 Viewer)
mark and sharon
42
15
Lutterworth
Sun seeker
a newbie
Hi guys
Loving the forum. We have just bought a fiat ducato van conversion and would like some advice on bike racks.
We can buy a door mounted bike rack, or have a tow ball fitted and fit a bike rack to that.???
Sharon and mark
mark and sharon
mark and sharon
42
15
Lutterworth
Sun seeker
a newbie
Hi mike
Good point that would be the down side. Concerned about lifting our old heavy bikes high. Also will the door take the strain?
Regards Sharon and mark
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
Tow ball mounted every time for me. Unless you have very light bikes it will be a struggle to lift them up otherwise. And mechanically the tow bar mount is much better. Doors can be bent with the alternative especially if you hit a sleeping policeman at speed.
4,169
5,155
Market Rasen
Self Build
Since 2003
I have the door mounted one but I have bolted both rails on through the door. I also have the bike channels on the lower position and fitted extra lights at a lower level.
461
377
Lincolnshire
PVC, S&L Iveco
45 years
We have a door mounted rack on our current PVC but due to the problems of lifting heavy e-bikes up high we are going to use a towbar one on the new van. We have found that the Witter rack tilts almost horizontal which most do not and should allow the back doors to at least partially open.
Murphy
92
53
Mansfield
Shire Conversion
We had bike rack fitted to our PVC on rear door for carrying our 2 mountain bikes, seems to
carry them well, but would not carry any more than 2 bikes, the rear doors open fully with bikes on but you have to be careful closing the door with the rack loaded,
Carol
14,051
112,112
North Wales.
My thoughts would be if your fit and strong go for eigher, but for a easier lift go for the tow ball.
Riverbankannie
10,533
61,537
Bristol
IH 630 RL PVC
We were advised not to have door mounted rack on our new Ducato by converter.
I Did have a fitting for a swing out towball mounted rack by Busbiker in holland. Cancelled it when I weighed van and found that tow bar plus rack plus electric bikes would take us over weight.
1,888
305,192
Wales
Adria Coral 660SP
25 years
I always worried about the strain on the door hinges! Even on my Freelander, Land Rover advised against door mounted bike racks, it's not the standing weight, it's the 'shock' loading when you hit a pothole, even though the doors are closed there is a 'peeling off' effect.
Land Rover supplied a bike rack that mounted on the tow bar plate. This meant I could still tow the caravan with bikes on board.
Link Removed
My Thule tow hitch bike rake is designed so that, with a bit of spannering and effort you can 'drop' the bikes back to gain extra access space.
Either type did require a plate and lights board.
1,372
4,148
Cheshire
Van Conversion
Been around the block a few times😉
Slightly off topic :whistle:
We have a Witter 3 bike rack.
I'd like to carry our 20kg awning on it in France/Spain would we have any legal issues ? Also would we need a reflective board?
1,888
305,192
Wales
Adria Coral 660SP
25 years
I would imagine that as long as;
It is secured.
Not flapping about.
Does not exceed the weight limits of the rack.
Doesn't obscure the lights, number plate, number plate lights.
No one will care, but how nickable will it be?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I prefer um up high out of harms way in case of a rear shunt, also when you make it easier for yourself you make it easier for the tea leafs too:doh:
12,139
18,005
derbys
AUTOSLEEPER SYMBOL
Our door mounted rack didn't seem too high when I fitted it eight years ago but it seems to be getting higher year on year.
Or are you getting shorter,,,,,:D:D BUSBY,,,,
TheBig1
17,630
43,275
I would recommend you fit a towbar and take a good look at the dutch bike racks. they unclip from one end and pivot out of the way of the doors
mark and sharon
mark and sharon
42
15
Lutterworth
Sun seeker
a newbie
Hi john
That is amazing. That's what we need (want that one!) We puck up our new van end October. Adria sun living. Shame they do not have a UK supplier. Expensive like you say but design perfect.
Thanks for sending link. Sharon
rich g
480
855
Worcester
A/S Warwick
since 2013
I have just had a tow bar fitted to my PVC, and bought a Thule bike rack,i was advised not to attach a rack to the door.
Riverbankannie
10,533
61,537
Bristol
IH 630 RL PVC
This is the person to contact at Busbiker
theo@buscamper.nl
I came to the conclusion that even the witter rack that tilted would not allow any useful access to the Ducato rear door so the Busbiker rack was the way to go. It was recommended
mark and sharon
mark and sharon
42
15
Lutterworth
Sun seeker
a newbie
Thank you riverbank it's so good to have a contact person. Will let you know how it goes.
Regards Sharon Mark
