Big water leak
Discussion in 'American RV's' started by bandit, Jun 8, 2013.
  1. bandit
    bandit Funster
    Oct 2, 2011
    221
    112
    Widnes,Cheshire
    Afternoon all,on this glorious day,went away on thursday after work got back lunchtime today,weather superb.Down side my fresh water tank as sprung a bad leak.I rang Star Spangled Spanner,he could not do any thing,Ive tried sealing itbut to no avail.So some sujestive input would be grately received..everybody av a nice week end.:Smile::Angry:THE BANDIT
  2. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Bandit
    For a quick temporary repair you could try EVO-STIK Plumbers Mate...It's an epoxy putty seals under water and is for pipes,tanks etc, I've used it pretty good you can get from most DIY places and some Tesco shops stock it
    When you get home dry the tank out and repair it with Arraldite resin if the hole isn't too big.
    Good Luck :thumb:
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,208
    3,621
    walthamstow east london
    plumbers mate isnt much good for sealing holes its more for sealing waste fittings and as a bedding for taps
    its goiing to depend on whats actually leaking a hole in the tank can be filled with araldite or similar but unless youve been cross country its more likely to be a pipe or tank connector thats worked loose that will need refixing or replacing
  4. bandit
    bandit Funster
    Oct 2, 2011
    221
    112
    Widnes,Cheshire
    thx Tony
    Hi tony,thanks for the thread,im afraid its a bit more than a hole,its leaking like sieve,out of many holes.Sent C.A.K tanks an email to see if they can put an after market tank in,So i will av to use potable water tank for the moment.Thx again Tony.:thumb:
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,389
    5,415
    East Sussex 01-580-881288
    Fiamma tank any good?
    Fiamma 70 Litre Fresh Water Tank
    The Fiamma 70 Litre Fresh Water Tank made of non-toxic material. It can be installed either vertically or horizontally. Comes complete with all necessary fittings for installation.
    Water inlet pipe size Ø38mm and air outlet Ø13mm. 70 Litre capacity tank ideal for conversions or replacement. Comes Complete with fixings
    Size: 700mm Width x 240mm Height x 470mm Depth
    Peter
    • Like it Like it x 1
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    you are thinking of different stuff with the same name
    http://www.bostik.co.uk/diy/product/evo-stik/Plumbers-Mait-Quick-Leak-Repair-Putty-/128
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,769
    6,290
    South yorks
    That's quite a good price Peter :thumb: less the funsters discount of course :BigGrin:
    terry
  8. bandit
    bandit Funster
    Oct 2, 2011
    221
    112
    Widnes,Cheshire
    thanks Peter
    I might av to resort to the fiama tank,if C.A.K cant come up with something.I wont know till they get back to me.Thanks again for your imput.:thumb:.THE BANDIT,aka PHIL
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,088
    17,759
    YO11 2BD
  10. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,208
    3,621
    gf fabrications in hull will make any tank to order very reasonable and fast service im sure they could copy your original
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,719
    10,148
    always good to know about companies that can do bespoke work. often off the shelf parts just dont match original parts
  12. TheBig1
    Nov 27, 2011
    7,719
    10,148
    when reinstalling the tank, whether repaired or replaced, add a sheet of aluminium chequer plate to the underside to protect from damage from beneath
  13. bandit
    bandit Funster
    Oct 2, 2011
    221
    112
    Widnes,Cheshire
    Thanks Papajon
    THanks for that useful thread,ive bookmarked it,also a good idea to put cheqer plate on bottom stop damage.I will look into it tomorrow.Thanks again everybody,who has given me a lot of useful info,i will keep you posted how im doin.This is what forums are all about,people giving info,much appreciated.:thumb:...THE BANDIT,aka Phil
