Big holes, screws loose!! (1 Viewer)
Jun 6, 2012
1,138
1,536
Leeds
Since 2012
If your anything like a lot of us with MH's who are always fiddling and enhancing and making additions you probably come across the problem with screws not tightening into wood anymore! I found this especially a problem when in some panels the wood is fairly thin so the usual solution of using matchsticks or cocktail sticks won't really work.
Anyway yesterday I had a few loose holes so decided to try another method and can report its worked with VERY good results.
It's simply using toilet paper and wood glue. I used 3 sheets of toilet paper and a spoon full of wood glue. The tissue paper dissolves immediately and it leaves a paste. I filled the offending holes, wiped clean and left to set overnight. Just screwed the screws back and it's as strong if not stronger as the wood itself!
Feb 9, 2008
8,943
18,691
Corby, Northants
Coach Built
Cool! I have found epoxy glue from the pound shop does a great job too and can be used on just about any material both inside and outside.
movan
21,492
120,753
Moving around
Burstner
since07
Well apparently I could use this ... I have a few screws loose that need fixing.;)
JockandRita
11,446
149,809
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Unfortunately Joy, the chemical in the glue would irritate your sensitive skin. :whistle: Just saying like.........
Cheers,
Jock. ;)
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
Great solution. Add sawdust to hide repair if needed
May 8, 2016
1,685
80,442
silver coast, portugal
C Class: Low profile
Boatie for 20 years
A great tip, thanks for posting this as I have this problem in a brand new van. I was thinking about cutting down some small plastic plugs and then gluing them in with epoxy, but this is a far more elegant solution
Edit: sawdust addition also good idea
scotjimland
2,241
9,748
A Woosh bang
would this have any .... let's say.. medical uses ? :sneaky:
