Best way to wire solar panel in (1 Viewer)
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
I'm thinking of getting a 120 panel & fittings through local Maplins so I can go hook up free for a week at a time. My Hobby 600 is fitted with 2 x 110 batteries that are some distance apart. I have heard that it is best to put the positive from the panel on one of them and the negative on the other.
Is this right, I dont want to ruin everything on it.
Feb 27, 2011
14,709
75,756
UK
Self Build
In a perfect world this is the way to do it. In the real world it doesn't make a huge deal of difference. Providing the link cables between your batteries a of decent size just put the solar panel cables to the most convenient battery.
tonka
10,825
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
And why pay Maplins price.. !!!!
Go to ebay... :winky: Will be half or even less of the price....
Mapling 120w £449 - ebay kit £284..
You could get 2 x 80w panels and have 160w for even cheaper if you have the roof space..
vectian
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
Thanks Gromet, Yes the cables between the batteries are boh ood thick ones from the charger. Looks like I'm climbing on the roof soon then.
vectian
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
Tonka thanks for the suggestion but in store theyve a 120 watt kit including controller etc for £280 which seems reasonable & I can go and shout at them if anythings wrong with it
tonka
10,825
21,514
Cannock, Staffs
Since 2000
Ah... Not so bad then..... :)
Good luck.. Its not a hard job..
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
good site here for info :
Link Removed
I now have two 100w panels bought on eBay no problems at all (mine cost £74 each with p/p 30amp charge controller total cost around £200 including all brackets and wiring (wired to one of the 115amph )batteries and batteries inter-connected with HD cable,
Have a Maplins right on my doorstep which I sometimes use but over priced on most things
Link Removed
Charge controller :Link Removed
tonka
10,825
21,514
Cannock, Staffs
Since 2000
Just a note on that 120w kit....
Found it here on ebay,,
Link Removed
I note that the sikaflex sealent, panel fixings and a few other bits are missing from the more expensive one in the catalogue.. Also regulator is only 8 amps, Bit on the borderline I would have liked at least 10amp maybe even a 20amp to be on safe side...
