Best Way to Make 12V Waterproof Joint (1 Viewer)
spindrifter
43
Hi All
Advice please. What is the best way to make a 12 volt waterproof joint under the motorhome running along the Alko chassis - for 4 x LEDS - very low current useage?
Have considered thus far:
Solder and shrink wrap. Scotchlock. Waterproof junction block.
Any thoughts please.
David ..... Spindrifter
Oct 14, 2007
3,958
6,134
Rochester
Auto-Trail Mohawk
16 fun filled years
Solder and shrink tube then self amalagamating tape
Scotch locks a not a good idea for permanent joints, ok for emergency in my opinion:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
The correct method is a waterproof junction box as used on trailers etc but then you knew that didnt you:Doh:::bigsmile:::bigsmile:
failing that, Danes suggestion would do the trick
Geo
bobandjanie
8,144
15,700
Javea, Spain
Pilote V600g
Hi, I was going to say :winky: If you want a Dry Joint :winky: solder can make a good one.:Doh: But I would use a waterproof junction box, after having lorries,:Doh: you will find it a lot easier to find a fault (if you have one ) with one fitted. :thumb: Bob.
Sep 23, 2007
1,702
1,966
Leicestershire
4 and many as a tugger
We use IP65 rated Stainless Steel motors. The conections are made by soldering the wires and heat shrink tubing that has a coating on the inside that melts with a heat gun. The terminal box has no seal just a lid. these are 400v three phase and being washed down countless times a day, never had a problem. Bought some of the tubing from fleabay.
Andy
S
stagman
You can't go far wrong than following Diabalo's instructions . Just take your time and use good tabe making sure you stretch and keep it warm before applying:thumb:
spindrifter
spindrifter
43
Andyman
Could you tell me the name/type of the heatshrink that has the coating inside please.
Thanx
David
Sep 23, 2007
1,702
1,966
Leicestershire
Look on Ebay for Heat Shrink Glue Lined or Heat Shrink Adhesive.
Heres one
Link Removed
Andy
Feb 25, 2008
232
96
Barril da Alva, Portugal
Caravan
on and off for the whole of my existance
another option!?!?!
I have for many years used insulated female and normal male spade connectors, but put the wire into vaseline before crimping and then the male spade in vaseline before connecting the two together.
I have used this on landrovers/trialers which are regulaly submerged.
The heat shrink i agree is good, but when a slight crack/split accures the water gets in but cannot get out, causing problems.
Happy wiring
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Rescue tape-its the dogs danglys!!!
Link Removed
