best way to fix a solar panel
Discussion in 'Solar Power' started by kamperman, Nov 14, 2009.
  1. kamperman
    kamperman Read Only Funster
    Apr 24, 2009
    18
    staffordshire
    Hi whats the best way to fix a solar panel to the roof without making holes in the roof theres already to many, Taken me ages to fix all the holes put in by previous owners you would not believe how they fitted a top box any help would be appreciated. Panel is 17 "x 37"
  2. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    Use Aluminium " L " brackets screwed to the sides of the panel and glue to the roof using Sikaflex 512 .
    Mark
    • Like Like x 1
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,606
    3,858
    roche cornwall
    bond two peices of aluminium angle to the roof with sikaflex . screw or rivet solar panel between them.use sikaflex to keep cable stuck to roof as well maybe make the angle big enough in length so you can add another one as time goes by.
  4. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :Cool: Same here. :thumb:
  5. kamperman
    Apr 24, 2009
    18
    staffordshire
    fix solar panel
    Thanks C.L.S and VWALAN I was thinking along similar lines but wasnt sure which adhiesive to use would you sit panel on roof or leave a small gap between.
  6. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Hi Kamperman
    Mine was fitted by the motorhome Dealer/agent when we purchase from new.....French agent.....what they have done is, sat the panel on lots of what looks like Silicone (thick layer 1/2" on corners and middle) like dot and dab when you fit plaster board on dry lining.................I would not say it looks the neatest but it works and no holes through the roof of the motorhome...that must be a good thing.
    Mel
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    you should leave a gap underneath as they do get quite hot i believe.
    mine has a 4" gap.
    if possible fit a small plastic fairing infront to deflect wind while travelling or you could loose it if only 'glued' down.
    you can get them from the likes of o'leary's.
  8. vwalan
    vwalan Funster
    Sep 23, 2008
    7,606
    3,858
    roche cornwall
    personaly i always lift them off the roof to allow air under neath they can get warm . i use 3in angle .its not cheap . of course it helps if they are already in an aluminium frame some are a little harder as they dont have their own square frame .i hope yours as. if not do it first . older panels had bolt slides on the side of the panels .
    some do mount them on sun seeker tilt and swivel frames but they can be a bit expensive.mine are always trying to seek out the sun .dont know what happened today. anybody got any rain power panels. tried the lunar panels but they kept me awake at night with the light. :Rofl1:
    psif you put the angle across the roof you wont get them blow off and branches cant get underneath. i do go some silly places.
  9. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Correct John ..
    They do get hot and as a result become less efficient so leaving a decent air gap is important !
  10. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I recommend that you first mount a luggage rack, check with the converter where the roof batten's are. Then mount the panels to that.
    This way you have the freedom to rearrange things if you want/need too. I also recommend that you make some or all of the panels hinged so that it/they can be tilted up to the sun.
    Plan for the unknown future!
    Doug..
  11. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    A good idea is to have the cable entry hole sited under the panel for protection and to prevent rain hammer.
