Best way to attach a reversing camera (1 Viewer)
Rapiscan
5
manchester
C CLASS
1 MONTH..RETURNING AFTER 20 YRS
Hi,im not sure whether to sikoflex my new wired reversing camera directly to the exterior rear wall of my kontiki or screw it on directly...or maybe bond a block of wood,plastic or alloy or similar first with sikoflex to the wall and then screw the camera to that?.The latter option means i only have the one cable entry hole as opposed to 3 screw holes otherwise....what dya think peeps what would/do you do? Thanks for any info/advice.:thumb:
Dec 4, 2007
282
17
worcestershire
Winnebago
20 years
Use stainless steel self tapers and put plenty of silicone in the hole,if you have cupboards along the top of the back wall drill though one and do the connection in the cupboard spend a bit of time routing the cables to the dash and pick the power up in the fuse box, we fit them and allow yourself about 3hours Paul
scotjimland
2,246
9,757
A Woosh bang
I used the same method as Paul.. s/s steel self tappers and silicone, I don't see any benefit in using a block of wood or plastic..
Ensure there is a small loop of the camera cable below the entry hole to the van, this will prevent water running into the hole.
Once fitted, pump silicone into the cable entry hole until it squirts out the other side.
Dec 4, 2007
282
17
worcestershire
Winnebago
20 years
Glad we fit them properly:ROFLMAO::ROFLMAO::ROFLMAO:
Spacerunner
607
197
Hampshire
If you have a bike rack think about adding an extra spar across the top of it and fixing the camera to that.
I have a two camera system, one for reversing the other as a rear view 'mirror'. I bottled out of fitting both to the rear wall and came up with the above solution.
I bought the aluminium spar from B&Q and used stainless screws. The cable I routed through the rear wall behind the high level brake light to protect it from the weather and sealed the hole with a liberal squirt of Sikaflex.
