best small inverter (1 Viewer)
beachcaster
3,044
3,161
east sussex
a few years
Something for the van that will plug into the ciggy lighter and will charge laptop/phones etc.
Any suggestions ??
thanks
barry
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Don't bother with an inverter, its best to get a dedicated 12 volt laptop and phone charger.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Chosse one you can easily return, I had a problem with a 150W inverter that would not charge a laptop. Watts OK but the load freaked out the inverter.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I have a cigar lighter one that has kept my laptop and phones charged up brilliantly on my boat for the last seven years. I have also just purchased another (slightly larger) which will need hard wiring in, trouble is I'm at work so when I get home I'll go out to the boat and get the details for you, can't praise it highly enough.
Regards.....Griff
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I have a 75w one ................. used it once for about 30 minutes to run my laptop only to find it was by then too hot to handle and had a flat starter battery:Doh:
Now I have a dedicated 12v to 19v DC adaptor very cheap from fleebay which works fine:thumb:
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
We have a Sterling 350W inverter.It is 'hard wired' and charges laptops,camera batteries,Kindles,electric shaver etc.We also use it to run a laptop for an hour or so at night when we are on aires.
Mike.
Feb 27, 2011
14,732
75,879
UK
Self Build
For charging phones and laptops I would strongly recommend a 12v converter rather than an inverter.
However for things like toothbrush chargers this is not possible :cry:
If anyone know of a very small sine wave inverter maybe 100Watts going cheap please let me know ::bigsmile:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
Hi, as mentioned earlier I would get home and look up which inverter I have been using happily for the last 7-8years on my boat and here it is.
Well I say here it is, but I bought the 150W version and then of course you need to know that you must use the correct size of inverter. Using too large an inverter will be almost as bad as using too small. So for Laptop and phones 150W should do just fine. Mine certainly does not get warm let alone hot.
Link Removed
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
As it happens.................
I agree with all who say go for the dedicated converters, but they are actually inverters too !
You cannot step up DC voltages, so the things take the battery voltage, convert it to a sine wave ( AC ) step it up, ( like a mains inverter but MUCH lower voltage ) and then converts it back to DC :thumb:
Onderweg
Jul 17, 2008
508
240
Vlissingen, Holland
As of April 2008
So we are talking about recharging using the USB connection ?
Link Removed
Link Removed
, now this one is a bit more than only to USB
Link Removed
Mind you these pages are in Dutch so you would have to use GoogleTranslate, hope this helps you
Paul and Ineke
