Best quality water tap? (1 Viewer)
Daveg
151
165
Perthshire
Low Profile
November 2012
We have a reasonable quality German van (LMC) with the usual mixed standard of bought in fixtures from the likes of Remis.
The taps seem to be by Reich, judging from the pipe fittings and they are splitting in the body or the spout or both. The kitchen one was replaced two years ago, so I'm not thrilled. We use the van heavily (been away on this trip since November), but not heavy handedly.
Are there better quality taps available that would fit into the hole in the sink (kitchen) and panel (washroom)? It's difficult to tell by looking at web sites.
Any advice would be appreciated.
Dave
sedge
Jul 7, 2009
5,504
13,113
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Well as long as they fit the water pipe you are attaching them to - and the same applies for house taps - you need to know that before buying any tap. We didn't drain down enough one winter and the kitchen sink tap 'blew' on the Bessie and Pete replaced it with a normal stainless steel mixer tap same as you'd have for the sink at home.
Damn sight cheaper than from a caravan etc accessory shop. Worked 100% fine.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Domestic taps have the same size tails & would be best - BUT not if your system uses tap microswitches to turn on the pump. If it's a pressure-switched system there is no reason (other than weight) not to use a domestic mixer.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
I've replaced the spout of our kitchen one twice. First time although the rest was drained down, a bit of frozen water split it and made it dribble. I replaced it, and that never performed satisfactorily having a dribble at the base from the outset and within months peeling chrome.
I had bought the first from a supposedly reputable dealer. However the second I bought was from a different dealer and seemed manufactured to a higher standard and didn't dribble.
I suspect that there are pirate Reich spares about. The price they are would make it worthwhile :)
Dick
Minxy
32,629
66,498
E Yorks
Carthago Compactline
As mentioned by sedge, if it isn't a micro-switch tap (ie no electric wires coming out of the bottom) then a standard domestic type mixer tap should be a better quality/cheaper replacement, and there's also a lot more choice too.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have solid chrome domestic taps in ours, no reason you couldn't fit the same if you have a pressure system
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
plus one for a domestic tap ours was a fold dowm one under the lid and we had 3 in two years gave up and put one next to the sink in the work top just used adapters from 1/2 inch to 12 mm pushfit
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
I too use domestic taps on all conversions with the exception of when a 9222 sink cooker unit is used -simply because I get them (fold down type) with the unit -They are micro switched but we just do not connect the wires and use a pumped system or if in a small van simply wire the pump to a switch rather than depend on the stupid micro switches (y) The hardest bit is/was finding the 15 mm to 12 mm push reducers but I have a good supply of them now ;)so almost all of the pipework is now done in 15 mm
terry
