Best Gas Option (1 Viewer)
Kenmare
Newquay
I'm a Newbie
Hi All
Have been reading this forum for the last few weeks and I have to say you seem a friendly bunch :)
I am planning on going to France Spain & Portugal for approx 5 months in January , I believe my calor gas bottle is going to be of know use over there for that period , can you advise on which way I should go on this issue i.e. gaslow etc
PATTYDOZ
24
17
Darwen Lancs
Van Conversion
The way we get past this problem is to have a barbeque point fitted.You can then buy a gas Bottle and regulator out their and back feed through barbeque point gas is cheap in spain all the best and good luck
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
Jaws
23,827
72,277
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
We went with Alugas due to price and as importantly, the very friendly advice and help from Alugas 2000 ( http://www.autogasleisure.co.uk/ )
We have filled up in about 15 different countries over the years using the various optional filling widgets
I fitted the system myself in about an hour, but if you contact the firm they will fit it for you while you wait ( and are supplied coffee and biscuits ! :) )
Reactions: DBK
11,137
17,716
HYMER B644
If you are in Spain, Propane from Cespa is cheaper than Butane.
There is currently no deposit for new contracts.
Only problem is you may need a Spanish address, NIE or a friend with one.
I bought an 11kG Cespa Butane for £9.75 having also just bought a 13kG calor for £28.75 in the UK :mad:
But if you need a lot of Gas and moving around a lot, I favour the Alugas.
TM
991
1,082
Edinburgh
Rapido 881F
Since 2015
Alugas for us can't fault it and when considering like for like there wasn't enough in it for me not to get is it fitted. Too chicken to start drilling holes in a new Motorhome!
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I had an underslung Gas-it tank on my Autosleeper which seemed to work well, I have recently fitted a Gas-it refillable bottle kit to our latest van. Had to drill a hole for the filler in the gas compartment door so I can fill it easily without opening the door. Quality of everything supplied is very good and it works fine. I can certainly recommend them, delivery was next day and they responded to a couple of enquiries almost immediately.
2,009
2,600
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I went for Gaslow in the end after lots of deliberation about cost, weight, safety etc.
The reason I went for Gaslow was that I could easily get one locally at the same prices Hamiltons do. The weight saving with Alugas is negligible and they are more costly. I got the fill pipe, adapters and filler from The LPG Shop.
All sorted DIY for under £200 (x1 11kg cylinder)
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Hello and welcome from West Midlands.
.... p.s. To get the most from the forum you will need to subscribe. It's well worth £15 and will allow you to continue posting as well as letting you into areas that non members can't access.
Wyn
Lenny HB
53,224
149,283
On the coast in West Sussex
Hymer B678 DL
I have Alugas 14kg bottles, they are the only ones that do the 14kg size. Had Stako on the last van they were getting tatty after 5 years, paint flaking off and going rusty.
