Bessecarr E410 Leisure Batteries
Discussion in 'The Beginner' started by mike9jr, Nov 27, 2013.
  1. mike9jr
    mike9jr Read Only Funster
    Nov 11, 2013
    42
    12
    Glasgow
    Hi again,
    Silly question time.... Bessecarr E410 2003 model.
    I want to replace the original 10 year old LB for a decent high power, long lasting one to allow for 2 or 3 days wild...
    1 - where the hell is it? Under the drivers seat? If so, is it a DIY job or do I need to find someone to do it for me?
    2 - Which battery to get... needs to be a good one.
    3 - (even sillier....) Does it recharge along with the cab battery from the alternator, or are they seperate...
    Excuse my ignorance, new to all this but very excited :)
    Ta
    Mike
  2. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,901
    Corby, Northants
    I posted this a month or so ago.
    Your question comes at an appropriate time, as the Caravan club magazine has just published at article on the subject.
    In short they selected 10 different band new leisure batteries and subjected them to a proper test to establish their true AH rating. 8 out the ten were not as stated with some being absolutely crap. Unfortunately the C.C. refused to name and shame them on the basis of only one battery being tested.
    The other two which they rated at being high quality batteries and meeting their test requirements were Varta and Banner.
    There you go, a scientific test that demonstrates these two batteries are A.O.K.
  3. Jim
    Jim Ringleader
    Jul 19, 2007
    26,369
    77,892
    Sutton on Sea
    Hi Mike,
    Exciting times when you get a new van. :BigGrin: Battery Location. I'm sure someone who has your model will be able to tell you, but do take a look under the seats as that is a favourite place for locating batteries. You may well have two and you may well have to remove the seat to get to them, but it's easy enough.
    If you have just the one, buy a 110ah, Banner are a good make, not sure where you'd source one in Glasgow, but people do ship them. :thumb: Best of luck with the new van:Smile:
  4. mike9jr
    Nov 11, 2013
    42
    12
    Glasgow
    Cool thanks.
    So I know a good battery now :)
    Can I change it myself and how does it charge? Is putting in 2 easy enough to do and wire up for a total electrical numpty?
    Went in the van today and sure enough there seems to be now battery power off EHU.
    Unless I'm doing something wrong, which is a possibility lol
    Mike
    • Like Like x 1
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,537
    9,954
    the leisure battery charges from the engine via a relay, which isolates it from the engine battery until the engine is running
    changing a battery is a simple diy task for most, but you need to be able to use a spanner and follow simple safety instructions. if mishandled batteries can be dangerous as they are filled with acid and in certain circumstances can explode if you short out the terminals
    assuming youre ok with all the above fitting a second battery entails finding a ventilated space to take the second and running 2 wires back to the first leisure battery
    i would say that if you are at all worried about youre capabilities to do this job pay somebody to do it as it would be better for you and the van. mistakes tend to be more expensive to fix than getting it done right in the first place
  6. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    784
    642
    Dumfries
    Mike, just been thro your process. Varta and Banner recommended as above. Varta and Bosch are identical apart from badging and available from Halfords or google for other local supplier. have fun:Smile:
  7. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,901
    Corby, Northants
    One final point you may want to consider! (I'm not familiar with your vehicle and electrical system). Just make sure your control panel and charging system are OK with two leisure batteries. If fairly modern should not be a problem and your user guides?handbooks should confirm that.
  8. Geordie and the Dragon
    Geordie and the Dragon Funster
    May 3, 2008
    193
    134
    North Wales
    When fitting an additional habitat battery ensure you use a stronger/heavier cable than the one normally fitted by the converter, to avoid any loss of current unless you are able to site the new battery alongside the original one :RollEyes:
  9. TheBig1
    Nov 27, 2011
    7,537
    9,954
    if doing the job yourself add a fuse at each end of the live cable for safety unless batteries are virtually touching then use 1
  10. mike9jr
    Nov 11, 2013
    42
    12
    Glasgow
    Awesome guys and gals, thanks loads :) :BigGrin:
    There is a space big enough (I think) behind the drivers seat where I assume the original LB lives.... so should be ok to join a 2nd LB to the 1st.... I think I can manage that myself.
    Another silly question.....
    While ON hook up to the mains, is the LB charged automatically, or do I need to flick the switch above the van door to force it to charge the LB....?
    Ya see, I said it was silly..... Possibly sillier than the originals!!!:Blush:
    Mike
