Bessacarr E795 Waste Water
Discussion in 'Bessacarr' started by Supertractorman, Jun 29, 2010.
  1. Supertractorman
    Supertractorman Read Only Funster
    Sep 7, 2007
    415
    3
    I am having a problem with waste water going slowly down the drains and then blowing back in shower tray. It is also fairly slow to drain out. Feels as though tank is airlocking.
    Is there a breather on the waste tank that could be blocked, if so where ? or any other suggestions please.
    David
  2. Doddy999
    Doddy999 Read Only Funster
    May 3, 2010
    160
    13
    Exeter Devon
    When I bought my 765, I had that prob very slow, I opened the valve & pushed
    wire up the outlet, some tissue stuff (think) came out then all of a sudden a
    huge gush all over my shoes:shout:
  3. Fatalhud
    Fatalhud Read Only Funster
    Nov 26, 2009
    289
    Nottingham
    When our waste tank is nearly full it gurgles up the shower drain
    Mine also use to take ages to empty, I split the pipe before the ball valve (make sure the tank is empty:Eeek:) and found it was clogged with gunge which was being held back by a 25mm disc, which was from a hole drilled in the tank at manufacture
    It now gushes out :thumb:
    Alan H
Similar Threads
  1. Bart
    12
    760
  2. Dave K
    29
    1,981
  3. Brightonian
    10
    594
