Bessacarr E795 Trauma heater
Discussion in 'Bessacarr' started by landscaper, Mar 19, 2013.
  1. landscaper
    landscaper Funster
    Mar 17, 2013
    234
    165
    Devon
    We have an air blown heater system on our Bessacarr. We have had two problems
    1. The thermostat is above the habitation door and, although set to go off at 30 degrees, this does not reflect the temperature in the lounge which is cold - has anyone had their thermostat moved to a better place lower down?
    2. We now have a problem in that the thermostat is not longer working and so the heating never goes off! it gets very hot now!
    Any advice would be gratefully received
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    probably wired within the wall boards and will be near impossible to move unless you start over and rewire from the heater controls to a new position.
    typical habitation builders....no real idea what they're doing.
    the recommended height for a room thermostat is 1.4mtrs, around 4ft6in, above floor level.
Similar Threads
  1. Bart
    12
    707
  2. Dave K
    29
    1,835
  3. Brightonian
    10
    561
