Bessacarr E445 charging problem (1 Viewer)
KeithTBRS
4
Lymington
Bessacar e445
Hi all
Wonder if anybody can help.
I have an e445, the house battery charges fine from the mains supply, but will no longer charge from the engine. I am sure this a simple popped fuse, but I cannot find which fuse, does anybody know the location.
Pretty sure this stopped working when the engine was started with mains lead still plugged in.
Many thanks
Keith
K
KeithTBRS
4
Lymington
Bessacar e445
Did anyone one have any thoughts on this???
Hi all
Many thanks
Keith
meanders
Funster - Life Member
2,599
8,423
Ipswich, Suffolk
C class
Since 2004
Hi.
I suggest you start with Googling the swift site for the manual with circuit diagrams. On our 435 the 12 v fuse board is behind the drivers seat. Your's is likely to be in the same place. It's relatively easy to trace through.
Also, check your main control panel that you haven't inadvertently selected to use the vehicle battery instead of the on board. If you do, the engine will never charge the leisure battery.
Best wishes .... Robin
Debslo
Devon
fiat ducato
Hi I see you have a Bessacarr E445 . we've just purchased one... Any idea on tyre pressures . Ive hunted everywhere. Dealer says about 60 pSi . Seemed a bit vague . We are not heavy laden. Apologies I can't help you .
CWH
5,145
247,428
UK
WildAx PVC
From November 2013
Hello @Debslo and welcome to the Fun
KeithTBRS hasn't looked in on Fun since Feb 2014.
Tire pressures are a regular topic on here - I'd suggest you run a search, and/or start a new thread with a specific title for your question.
