Bessacar Light Cluster (1 Viewer)
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Had break light bulb go undone screws on cluster but plastic expanding sort of washers knackered what have i got to ask for on holiday at moment so need to sort thanks in antipation regards steve
angusboy
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Sorry im not good at that,but thanks its like a 2 inch screw type bolt with plastic clip that opens up across a hole try to get picture im morning its only a few mm thick and thanks steve
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Just a thought, but if the rear light cluster is like mine you do not remove any screws to change a bulb. The coloured lens for each individual light can be removed by pushing the clip via a hole in the bottom of each lens cover.
angusboy
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
thanks will i will look tomorrow and let you know but will have to change screws as took one out and others are very loose
