Beep beep goes the alarm (1 Viewer)
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
With fully charged batteries (twin leisure batteries) and an 80w solar panel on the roof why would the leisure battery drop down to an alarming level within 7-10 days?
Could the blocking diode in my solar panel be faulty?
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It could be:
Duff batteries
One duff battery
Faulty solar controller
Your use pattern
Overcast sky
Parked in shade
Faulty solar panel
Something drawing current full time (that you're unaware of)
Fuse gone
Etc
More info needed :).
Feb 24, 2013
13,082
101,444
Bolsover, Derbyshire
Hymer S800
not long enough
why?
nowhere near enough information given to guess
7 - 10 days is quite a time off grid
Have you driven any miles in that time
What country are you in
What have you used on the 12V side
what do you call an alarming level
If we park in the shade or use in cloudy weather, with only a solar panel and twin batteries similar to yours, a couple of hours TV per night, similar laptop charge via small inverter we would go critically low after about 4 days I would reckon, unless we move or the sun shines a lot
But we rarely stay still for more than 3 days partly for that reason (y)
Feb 4, 2016
2,784
2,128
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
Was about to post but the previous two posters said what i was thinking.
Oct 14, 2007
3,988
6,247
Rochester
Auto-Trail Mohawk
16 fun filled years
It could be you have parasitic drain. Google it for testing methods.
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
Assuming you are talking about the vehicle being parked up and not being used then they shouldn't be going flat so my first guess would be your solar system isn't working. To check this you need to use a multimeter and check the voltages through the system, starting with what the panel is producing when the sun is shining.
But even if the solar isn't working I would have thought two fully charged leisure batteries should last longer - so they may be duff or as suggested there is a drain somewhere. Do you have an ammeter in the system to tell you what is happening?
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
The simple answere is because, for whatever reason, you are using more than the panel is generating!
If you have been in the UK for the last seven days I doubt that your panel is working at more than about 30% efficiency, so a an 80w panel at 12v = roughly (80/12)*0.3 = 2 amps, for ten hours a day that;s only 20 amp hours which is half of bugger all if you're using fridge/microwave/tv/lights/hair-curlers/hair-dyer/coffee machine/laptop/phone-charger/nose-hair-trimmers etc etc etc
Solar is great but not a panacea for long term use (especially in the UK) if you don't size the system according to use and worse case scenario usage.
DanielFord
3,020
3,086
Couldn't agree more. We used our van over the weekend, we got to it on Friday.
We weren't using the inverter, but my daughter insists on having the light on over night. All other lights being used as normal. Quite heavy use on the TV and satellite receiver. This morning the leisure batteries were down to 12.1v so I have switched on the mains charger.
Over the last seven days the highest reading I have seen from the solar (150w) has been 2.9 amps. Due to the location, the highest reading will last about 2 hours before the sun goes behind some trees and puts the panel in shade.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Thanks for all of your input. I'm at a proper computer now so I can give more info.
The vehicle was on the drive not in use and would benefit from sun for most of the day. The two batteries are new 110ah Banner batteries replaced in the spring
This was last week when it was quite bright and sunny here just outside of Stamford Lincs.
Upon entering the MH the alarm was going off. I did not switch anything on or switch anything off (the habitation entrance door light came as normal). I then plugged in the hook up.
I went back two days later, unplugged the hook-up and took a look at the Sargent panel: Batteries charged, amps being used flickering between 0.1 and 0.2 amps.
I would imagine the Sargent panel takes some power. But the rapid discharge makes me think something else is taking the power.
My shortlist is:
  1. solar panel faulty and uses power at night
  2. tiny charger unit used for sim card location device
  3. alarm
  4. something else
I'm going to start pulling fuses and disconnecting stuff but I'll need to monitor the battery cables. Will my clamp on ammeter give a good enough reading? or should I break the circuit (disconnect the battery and use the leads)?
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
It HAS to be a failure in the solar panel system somewhere..
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
Have you got an inverter and if so have you left it on standby. I did this a couple of times and it brought down the batterycapacity quite a lot over a couple of weeks.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I'll check that at lunchtime
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
My shortlist is:
  3. alarm
  4. something else
Assuming you have a normal solar controller I don't think a faulty blocking diode would cause a problem - unless the controller can somehow work in reverse which I don't think they normally do. ;) It would only be a problem if the solar panel was directly connected to the battery, which is a very inefficient way of doing it but I suppose it might be if it was done by someone trying to save money. :)
I suggest trying to find out if the solar panel is actually producing anything first. Screwfix sell a good multimeter for about £10 - other suppliers are available. :)
43,323
49,440
0.2amps per hour
1amp per 5 hours
10amps per 50 hrs
48 amps per 240 hours (10 days)
That's almost 50% of your usable reserve and 25% of your total reserve.
Add to that any alarms etc and it will be even lower.
Definitely points to a faulty solar panel/controller or associated wiring/fuse.
Reactions: DBK
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
The solar panel goes via a "cheap" non MPPT solar controller to the Sargent panel. By going into advance setting on Sargent PSU I can see the solar input typically 5-6 amps on a sunny day.
Reactions: DBK
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
0.2amps per hour
1amp per 5 hours
10amps per 50 hrs
By breaking it down you've made it apparent that there is a draw higher than that shown on the Sargent system. Thank you. I'll go off and have some fun!
Reactions: DBK
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That's a nice bit of kit (if not a little big)
There is a smaller one and a new one that is hidden using a mobile phone for the display via bluetooth.
The bluetooth one seems like you'd forget about it after a week, you have to keep getting your phone out whereas one on the wall gives you the picture second by second.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
This will very soon be featuring on "What I Bought This Week"
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
I've got a BM 1, very useful to know what is going into or out of the batteries. But doesn't the Sargent thingies do that? Note: I know nothing about Sargent thingies other than they ate often discussed here. :)
DanielFord
3,020
3,086
Yes.... and no! :D
The Sargent in ours only displays the input and output that it 'knows' about. So on ours, it doesn't include current input from the panel. At lunchtime, the Sargent was showing a discharge of 0.8 amps, but the BM-2 was showing a charge of 0.4 amps. Those readings are with the fridge on. The water pump is on, but obviously not actually pumping. The TV and Satellite receiver are on but in standby mode, and there's a few other little things that draw a small amount of current, like the stereo head unit and the Sargent itself.
Reactions: DBK
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Yes.... and no! :D
Absolutely. So anything wired in that is unknown to the Sargent box won't be taken into account i.e. inverter alarms etc
