Bedding
Discussion in 'The Beginner' started by WynandJean, May 1, 2010.
  1. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,469
    1,405
    West Midlands
    Hello,
    Recently bought M/H and trying to find bedding to fit. Don't want to fork out for custom made but trying to find fitted sheets to fit 208x160cm. Most 'superkings' are only 200 in length. Anybody know of supplier whose sheets would fit?
    Wyn
  2. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,384
    Kirby cross further from londin
    we use a sleeping bag each lay it out job done
    or you can zip the two together
    or open it up and quilt over the top
    others probably have differant ideas
  3. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,297
    10,784
    E Yorks
    Why not get another sheet and cut it down so you can use a strip of material from it to attach to one end of the short sheet, afterall it will be tucked in any way so won't cause any problems, you can also then stitch 'corners' into the bottom to keep it in place too, like normal fitted sheets. With what's left you could make yourself some nice pillow cases/shams too.
  4. dylan
    dylan Read Only Funster
    Aug 31, 2007
    4,162
    569
    sw wales
  5. tonybrightspark
    tonybrightspark Read Only Funster
    Dec 31, 2009
    79
    Kent
    We bought Raskelf Duvalays the memory foam takes out any lumpy bits, very warm, roll em up into the bag 2 minute job. At £120 a pop not cheap but very practical.
    Although no good for superking.
    http://www.raskelf.com/duvalay.htm
    tonybrightspark
  6. Maddie
    Maddie Read Only Funster
    Nov 19, 2007
    252
    14
    Ashford, Middlesex
  7. HeleninAlnwick
    HeleninAlnwick Read Only Funster
    Jun 7, 2011
    Northumberland
    HI
    I use a padded mattress pad instead of a sheet - much more cumfy - not the ones with a skirt but one with elastic at each corner. It stays put and is much easier to put on than a sheet. I got mine from IKEA - not quite the same size but works ok. All you then need is a duvet on top!
    Helen
  8. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Just go for flat sheets - ironing fitted sheets is a nightmare at best - and flats give you a few mm extra play, and spare to bend around corner! Long as you are au fait with your hospital corners, they are far better.
  9. Cupcake
    Cupcake Read Only Funster
    Apr 13, 2010
    116
    11
    Norfolk Broads
    We use 2 quilts a winter weight + summer weight. In the summer use the winter one as bottom sheet & summer one as top & the reverse in the winter. Does 2 jobs saves all the struggle of 'tucking in' or stretching out a fitted sheet and also smooths out any 'lumps or bumps' from the cushions.
  10. Gooney
    Gooney Funster
    Jun 2, 2010
    4,765
    7,836
    Flintshire
    This is what we also use, got ours from Dunhelm Mill. It had elasticated sides so we just cut them off and use it as a matress topper, it really is very comfortable with sleeping bags on top.:thumb:
  11. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    We use two duvets.....one to sleep on the other over the top.
    With two different tog values....you choose to be hot or cooler depending which one is on top.
    Takes 2 mins to make up and 2 mins to put away.
    Works for us :)
    barry
  12. MHVirgins
    MHVirgins Read Only Funster
    Aug 22, 2011
    3,890
    3,165
    South of Scotland
    Bed Linen - motorhomes
    Hi All!
    I was glad I found these posts on here because I also had the same problem with the bottom sheet. I was going to buy a double flat sheet, but all this tucking in underneath the cushions was a pain in the butt and of course, it always gets left to the wife/girlfriend!:Wink: Men don't have the patience for this at all!
    Someone on a different forum said that they lie on a single duvet and had another single duvet on top, that idea sounded good, but wouldn't the duvet underneath you move and slide about everytime you turned during the night?:Angry:
    Someone else, (beachcaster) suggested a mattress cover with the corner elastics, rather than the skirt type and I think I might try that myself.
    I only have king size flat sheets at home and had taken one with us recently, but by the time I'd got it tucked all around the cushions I was ready for cpr!:Doh:
    We have gone for two single quilts rather than a double, but we're still learning at this early stage.
    Thanks to everyone for the different ideas!
  13. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Dont bother with sheets !
    Just get two duvets in covers........one high tog ..one low.
    Sleep on one........use the other on top of you..and swap around with changing seasons.
    Make the bed in a minute........put it away in a minute
    works for us :)
    barry
