battery
Discussion in 'Motorhome Chat' started by sinbad1, Jan 27, 2009.
  1. sinbad1
    sinbad1 Deleted User
    Your thoughts on this battery offered by oudoor bits http://*********************/elecsol-carbon-fibre-battery-p-714.html
    sorry link does't work (Elecsol 110 Carbon Fibre Battery)
    Are these batteries as good as they say, anyone using these carbon fibre batteries ?
    Not sure i'd be happy to receive a battery should it be delivered in this condition !
    Quote from outdoor bits re this battery.
    [FONT=Verdana, Arial, Helvetica, sans-serif]If some of the electrolyte has leaked out during transit then top us as necessary as follows. [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]To open the cells use a small screwdriver and gently press up not applying too much pressure.[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]If any cell is slightly low customer can add small quantity of distilled water. There will be absolutely no detriment to the batteries performance if acid had come out with carrier.[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]The battery requires no venting at all as the gases are recombined within the valve walls internally.[/FONT]
    Regarrds
  2. JJ
    JJ Funster
    May 1, 2008
    15,110
    27,217
    I bought a second hand (under one year old) one some years ago at great expense and it worked ok for a bit and then lost a cell. I replaced it with an ordinary leisure battery for a third to a quarter of the price and it worked fine but eventually lost a cell. Therefore, in my experience, the only difference was in price! I was told that the Electrosol would crank start my engine without damage because of its carbon thingies but as I naver had to do this I can't comment either way.
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    Switched to Elecsol batteries last December. So far they seem pretty good. I was comparing them with Exide Gel that were fitted as original equipment and against that standard, they were very reasonably priced - the gels would have been over £200 each.
    I have 2 x 110 Ah Elecsols which coped perfectly well with 2 nights in freezing conditions at New Year - no EHU. As well as lights, I was running DVDs on a laptop and powered speakers for 3 hours each night and the Truma was running 24 hours a day so there was a fair current draw from the fan. We still had quite a bit of spare power left at the end.
    New Elecsols use slightly different technology (Calcium) but still have carbon fibre plate strengthening. Mine have no sign of access to the electrolyte - they are sealed.
    You get a five-year guarantee with them too.
  4. olley
    olley Funster
    Jul 29, 2007
    3,907
    2,543
    Ipswich
    If theirs no detriment to loosing acid why put it in, in the first place?
    Lose enough and they won't be batteries anymore, just bl**dy heavy water tanks. :BigGrin::BigGrin:
    Olley
  5. sinbad1
    I've allways bought mid priced leisure batteries ;but their performance tends to drop off after a couple of years, just thought for a little more i could be better off in the long run?
    The 5 yr guareantee goes a long way in temping me to go for the Elecsol, they say its maintenance free , more efficient , and don't suffer as much from continued charge and discharge and the ability to cold start engines.
    Expect most batteries will claim to have various qualities ; but in practice ?
    Thanks for your feedback
  6. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,910
    9,450
    Tropical Bar,Benidorm.
  7. sinbad1
    exactly! i've sent them an email re: their quote if i do decide to buy this and it arrived in a damp packege, i will refuse to accept it. mind boggles at the statement:Eeek:
  8. sinbad1
    Thanks for the link good site, price is about the same perhaps a couple of pounds more.
    Regards
  9. scotjimland
    Jul 25, 2007
    29,040
    25,731
    Suffolk
    I can only reiterate what I have said in many posts.. imo , there is no cost or practical benefit in buying expensive batteries, lead acid technology is as old as the hills and hasn't changed in any significant way .. the five year warranty doesn't mean it's a better battery, it just means you are paying a premium to cover any failures..
    My four cheap 85ah FLAs have been in constant use for almost four years, three of them fulltiming, if they fail now I will still be in pocket as they cost less than half of a 'superior' battery.
    Remember..
    Most batteries don't die.. they are murdered ..
  10. sinbad1
    You could be right and maybe you have been lucky with your 85AH batteries ,
    I have allways bought the normal lead acid batteries mainly because i had a battery bank of 5x 110AH so it was an expense to do otherwise, and even with an expensive battery management they would only last max 3yrs.
    The battery i'm thinking of is approx half as much again, I do believe batteries have improved over the years.
    If i do decide on this battery and it fails after say 3yrs then it will be replaced by a new battery with another 5 yr guarentee which would make it cheaper.
    Regards
  11. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,895
    6,155
    Mansfield,Notts
    It most certainly will NOT, at best you will get the remaing two years on your replacements, and at worst you may be asked to contribute aprox hlaf price toward the new relacments if you want extended gaurantee back to 5 years
    I have to agree with Jim on this one
    using your logic you could have batteries for life:Eeek::Rofl1::Rofl1::Rofl1:
    Geo
  12. scotjimland
    Jul 25, 2007
    29,040
    25,731
    Suffolk
    Quote from Elecsol site
  13. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    In my experience from both boats ans Mh's the best value for pounds/watts is to by bog standared large cranking batterys, true they dont last as long as all the fancy ones but the pound goes further, ie for the same money you can buy 2 or 3 cranking batterys for the price of a rip off gel cell one.
    Doug...
  14. scotjimland
    Jul 25, 2007
    29,040
    25,731
    Suffolk
    Before committing to buying an Elecsol .. read here .
    http://www.caravantalk.org.uk/lofiversion/index.php/t9882.html
  15. sinbad1
    Maybe that is the case with the maufacturers ?;however even if you are right it still guarentees these batteries for 5yrs instead of 2 yrs. Doing my sums it still represents better value than the standard battery.
    Regards
  16. DJP
    DJP Read Only Funster
    Nov 4, 2008
    39
    Somewhere in Europe
    Try claiming. I believe it may be a problem:Eeek:
    Warranty begins at the date of the purchase of the first battery and ends 5 years later. If the battery failed at say 3 years, a replacement one would only have the unused balance of the original 5 year warranty. Or should have:Wink:
    If a battery is going to fail under NORMAL usage. i.e. NOT mis-used it would normally fail within the first 3 months.
  17. sinbad1
    Thanks for the link , does initially put you off with the poor service thread ; however, reading the whole thread Elescol did replace his battery and did appologise and give assurances that this was not the norm, other have commented that they have no problem with these batteries ,and one guy has had one for 7yrs.
    I think with any company that sells a huge amount of products are bound to receive some complaints , something I'll have to weigh up ( more googling i think).
    Regards
