Battery ? (1 Viewer)
MickyP
224
72
Alhama de Murcia, Spain
Sunlight Cliff 601
12 years plus
Can a Battery just die with no warning?
Used my Campervan a week ago all well yesterday could not unlock with Button had to use key this trigerred the Cobra alarm, but can not start engine. put vattery on charge over night and all day, still cant start engine, Batt monitor shows battery flat and leisure batt OK. Can hear a relay or something clicking when i try to start it does this mean the Battery is dead? Will i have to Jump start it to get to Garage?
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yes it can.. but did you take the battery out to charge it or do it in place ?
If in place fine, but I would suggest you undo both the terminals, clean and refit afore lobbing out a load of your hard earned on a new black box full of electric :D
MickyP
MickyP
224
72
Sunlight Cliff 601
12 years plus
charged in place still connected, heavy duty deisel battery charger. semms to had little impact
icantremember
8,332
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Are you sure the battery in the remote is ok because if you locked the m/h with the fob and unlocked by key the alarm and immobiliser would stay activated
MickyP
MickyP
224
72
Sunlight Cliff 601
12 years plus
The Battery is Dead has been fine all along the nothing, I finally found my multimeter and the battery registered a little over 9.3 volts no wonder it wont start, it also will not charge, I jumped the van and it started fine and runs OK so tomorrow off to the Local Bosch Garage in search of a new battery. Hopefully they will fit as these are not easily accessible? Can only just get the Jump lead on?
