- Jul 5, 2013
- 11,723
- 13,701
- A class
- Since 2013
I am going to replace my single old leisure battery with 2 new ones wired in parallel. What size wire should I use to run between the two batteries terminals? Is it just case of adding a wire to the existing clamp on each terminal and then running that to the clamp on the equivalent terminal of the other battery? By the way they will be sitting next to one another so a very short run involved.
Thanks for any help you can give.
