Battery Warning Light Fiat Ducato 2.8JTD (1 Viewer)
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
Hi there people
Sunny weather inspired me to ready my van, low and behold van battery dead!.
I have periodically checked during the winter months for damp, leisure and vehicle battery levels etc.
The vehicle battery showed only 7.5 on the habitation panel readout, van step wouldn't even slide out and a gentle ticking was coming from the engine... alarm with not enough power?
A 30min charge put the battery up to 13 and hey presto all systems GO. The engine fired immediately and step operational.
However, a battery warning light remains lit on the dashboard even when the engine is raced. Everything else is in working order but I suspect the battery may not be charging properly.
I must confess I may have crossed a connection when putting on the charger leads.
Can you please help me.
wasp
1,724
18,180
Warsop
None gone caravannin
you need to check if the alternater is charging, there might be a fuse blown if you fitted the leads on the wrong way round:thumb::thumb:
pwilmo
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
Thanks for your speedy reply, I am completely thick when it comes to electrics would the fuse be on one of the fuse panels or on the alternator itself?
wasp
1,724
18,180
Warsop
i dont think there is one on the alternator check the panel I know on mine there is an in line fuse on the battery lead failing that an auto electrician:thumb::thumb:
43,323
49,440
a 30 min charge will be enough to start the van but the battery wont be anywhere near charged.
it could be the voltage is still so low that the alternator cant detect a voltage and set itself in action.
try placing the battery on charge overnight then try again.
let it stand for a couple of hours then put a volt meter across the battery terminals and check the voltage...should be around 12.6v.....
start the engine and check again...it should be around 14v at idle or just above.
pwilmo
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
Sorted
Hi every one
Just a quick update, firstly, thank you all for your speedy replies and help.
I admitted defeat with my non existent knowledge of auto-elec-trickery.
Off I scooted to a local auto electrician (wad of bank notes in hand ready!). After a rub of the chin and a few PPhhraaws, it was diagnosed that my alternator configuration was the worst and most expensive. It would take a couple of days to dismantle, order part and fix. Oh dear thought I.
But first a check on the fuses on the battery top. Lo and behold ... YIPEE !!! the large alternator 150? AMP fuse was shot, frazzled.
Job done: cost was ÂŁ35 total; expensive fuse eh?
Alternator warning light off, all back to as was.
A long story but hope you enjoy.
