Battery state (1 Viewer)
Feb 9, 2008
8,949
18,704
Corby, Northants
Coach Built
Advice please!
I have fully charged my leisure batteries (New) and disconnected them. I intend to moeasure them with a multi - meter (Digital) once a month through the winter months.
How low (12.3?) should i let then go before i recharge them and can you estimate how long it would take to discharge to the level it needs recharging.
Thanks in advance,
Philip.
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Advice please!
Thanks in advance,
Philip.
A Battery at rest will be fully charged at 12.8v and fully discharged at 11.8. If you only have a bog standard charger leave it on untill the charging voltage reaches 14,2, if the battery is a good one the excess voltage i.e. above 12.8 will hold for many days.
If you have a small charger; think about leaving the connected to the charger via a timer switch set to 15 mins a day, the will stay topped up forever...
Doug...
Losos
549
4
Suffolk & Czechland
Looking to buyi
N/a
Thanks in advance,
Philip.
Sorry Philip, that's a bit like asking how long is a piece of string ::bigsmile:
You'll need to say what load you are drawing and for how long, to keep it simple take the watts of all the kit you have and how long each is on per day.
Then someone will likely come back to you.
Losos
549
4
Suffolk & Czechland
Looking to buyi
N/a
Doug...
Doug, I know there has been a discussion on another thread about 'ball park' figures and not confusing people but I'm bound to say IMO the battery will only last for many days if it is large (Amp hr wise) in relation to the load (Watts)
So with greatest respect aren't we in danger of making it all seem to simple for Philip especially if he has only an 85A/Hr. battery and he likes to run something pretty heavy all night ???
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The guy says he has DISCONECTED them, so he won`t be drawing anything from them.
Keep it simple.
Douglas
2,835
400
South Wales,
Re-read the original message by the author. he is disconnecting the batteries after charging and not putting them on discharge...
Doug...
Douglas
2,835
400
South Wales,
Doug...
43,329
49,444
Advice please!
Thanks in advance,
Philip.
every battery has an internal (self) discharge rate and evey battery will be different....even new ones.
look at the chart and dont let the battery go below 60% full.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I've just bought a Sterling inverter and it's low voltage warning is set at 10V and low voltage cut off at 9.5V.
That is at odds with your table yet I thought Sterling were a reputable firm.
Though that is obviously on load voltage.
43,329
49,444
no it isnt Brian.....
the invertor will pull the battery down to 9.5v pretty quick but as soon as the (heavy) load is removed the battery will show the true state of charge which will probably still be 12v+.
drain it quick and it recovers...drain it slow and it doent recover.
your fully charged starter battery may show less than 9v when cranking but straight back to full charge if you stop cranking.
(unless its an old ford then you'll flatten it anyway....Ruh Ruh Ruh RuhRuhRUh Ruh Ruh !!!!)
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
The batteries in my land rover remain charged for many months if disconnected, however why not just put a small solar panel on them a 10W panel would be ample to keep them in good order
Tony Lee
274
I don't think you specified exactly what type of battery you have. Three main general types - normal lead-acid flooded cell, AGM and Gel.
The first has the highest rate of self-discharge and in hot weather may lose up to 30% of its charge in one month. Winter will be a lot less but you also run more risk of the battery freezing so it is best to err on the right side and re-charge the battery when it has dropped say 0.25V below what it was on the day after you disconnected it.
AGM and Gel can be left for at least 6 months before worrying about recharge.
This assumes that you did actually charge them up fully to start with and that means at least a three-stage charger going through a fully cycle of bulk charge, equalisation charge before dropping to float for at least a few hours.
100% charge is indicated by a voltage of at least 12.6V (but it depends on the battery type and could be 12.8V) measured the day after you disconnected. If it was 12.5 or less, then the battery charger is not doing a proper job and you would need to recharge more often.
Johno
87
38
Kent
Low Profile
30+ with caravanning & camping
I have been using an "Airflow" battery conditioner to keep batteries fully charged for some years and have found it to be ideal,I believe they are very popular among the classic car fraternity. It's a neat little job measuring about 100 x 50 x 50 mm and made in Switzerland therefore not particularly cheap at just under £40 but it does the job for me.
John.
beemerboy
8
wemyss bay(where?)
roller team
batteries
I was told by an electriction friend that if you let your batteries discharge over winter months(in this case a boat) then the plates inside can warp and the battery will be incapable of taking a charge later to this end i keep my batteries charged when not in use.on the van I have a present i got stuck with the step extended because the battery was flat-not long after I bought it , on looking into the battery top up holes the plates were twisted- new battery not a spark but bright enough to know the cost of a leisure battery to keeping it charged
Ruddy
99
Haverhill,Suffolk
Coach Built
> 1yr
I have some of these connected to 4 bikes,1 jetski and the motorhome batterys, Never had a problem with them and £12.99 ea
Just fit and forget.
Link Removed
43,329
49,444
i dont think the plates warp but they appear to look that way.
it will be an uneven build up of lead oxide on the plates and its this lead oxide that prevents the battery from accepting and holding charge.
keeping a battery well charged breaks down and prevents further lead oxide forming.
if the battery hasnt been dead flat for too long it may recover by charging at a relatively high charge rate....14.8v or slightly higher.
this breaks down the oxide and exposes the plates to the electrolite and starts to accept a charge.
but, as you keep it charged, you wont have this problem.:thumb:
lebesset
760
a big thank you to philip !
normally my landie gets used during the summer period , then sits in the barn for the winter with the other vehicles while we go off in the motorhome ; this is more than sufficent to keep the battery going so that in the spring I can turn the key and away she goes ...if anyone knows the old landie series 3 diesel they will know that is no mean feat
but this summer , instead of staying home in the garden we decided to make a special trip , so landie didn't get used at all , rather it got forgotten ...until I read philips post today
so up to the barn , out with the meter and , after 11months ....12.0 volts instead of the fully charged 12.7 [ battery is [still ? ]good but not new
so does that answer your question philip ? how low does it go ? tomorrow will take the charger off [ 8 amp but battery only taking 6 amp when I switched on , not a lot for a 90Ah ]; then will leave for a day and see what we have
where did I go in the summer ? after the le mans 24hour we went to an island we hadn't visited in the summer for 20 years . don't know if you have been there , it's called great britain , people are a bit odd but other than that a great place to visit
PhilandMena
Feb 9, 2008
8,949
18,704
Corby, Northants
Coach Built
Pappajon,
Many kind thanks, this is exactly what i need. the batteries are both new & 115 amp. both located under the front seats of my motorhome. Hence, disconnected and left in situ. My plan is to let them discharge to 80% (the advice i received from the caravan club was never let batteries drop below 80% of total capacity and when fully charged they should provide 12.7 volts) . Your chart seems to be spot on and when the batteries drop to 12.5 v. I'll reconnect them bring the Motorhome - home and charge them upagain over the weekend.
I've currently got the Cab battery on long term charge with a modern charger, in my conservatory. I hope it will take several weeks to for the leisure batteries to drop 20%.
Thanks again for your kind help.
Philip.
43,329
49,444
i replaced my 110ah with 2 new 110ah's and charged the old one in the garage with a 10amp charger 'til full.
6 months later it still showed 75 to 80% so recharged and stuck it back in the van.
i now have a 330ah battery bank.:thumb:
