Battery State Indicator.can You Trust It?
Discussion in 'Tech/Mech General' started by friar tuck, May 21, 2015.
  1. friar tuck
    friar tuck Funster
    Nov 15, 2011
    156
    85
    redruth cornwall
    i recently removed a leisiure battery that was performing well but the little indicator window was black,meaning dead battery!i took it off and put it under a small load for 12hours drawing 1 amp it held up fine losing a miniscule amount of voltage.
    What are these little windows and how do they work?
  2. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,922
    3,919
    Corby, Northants
    They are a visual indicator of battery state. To measure battery, best use a volt meter. To test battery, fully charge, remove external power/charging source,allow to settle, put known load on for x number of hours, remove load, allow to settle. measure battery again with Volt meter.
    • Like it Like it x 1
  3. andy63
    andy63 Funster
    Jan 19, 2014
    2,253
    8,623
    south shields
    hi friar, I think the indicators built into the battery are small hydrometers .. they tell you the state of charge by measuring the specific gravity of the electrolyte and also give an indication of the electrolyte level..
    its sometimes possible to top up the battery with a little distilled water if its indicating its low...
    I thought dark of black indicated it needs a charge, but not sure...
    charge it up and run a good load on it and see how its held a charge... if that proves good recharge and continue to use, or at least I would...
    ta andy
  4. friar tuck
    friar tuck Funster
    Nov 15, 2011
    156
    85
    redruth cornwall
    Hi Andy thanks for the reply.electrlyte was a little low on all cells so i topped it up i wonder if the hydrometer part had drained? seemed to work ok on a load so its gone back on the mh now and the solar is bringing it back up to full.
  5. andy63
    andy63 Funster
    Jan 19, 2014
    2,253
    8,623
    south shields
    it will only have drained if the electrolyte level dropped which you have confirmed... very simple device... its just a little coloured ball floating in an open tube which is immersed in the electrolyte..
    hope its good for a long time to come... check and see if it returns to green when the battery is charged..
    ta andy
  6. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,433
    6,075
    St. Helens MERSEYSIDE
    My 2 Batteries showed ok on the green indicator but were as dead as a dodo:rolleyes:
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    The indicator only measures one of the six cells. It can look perfectly healthy whilst still having a dead cell.
  8. friar tuck
    friar tuck Funster
    Nov 15, 2011
    156
    85
    redruth cornwall
    Techno100 hi,if i have a dead cell would my battery still read 12.8- 12.9 and run a small load (1 amp) for 12 hours with negligible volts drop.im hoping not so i can conclude the batteyr is healthy.
  9. Techno
    Jul 28, 2010
    14,189
    15,163
    No a dead cell would lose 2.5 volts off any reading and be quite obvious. Generally a battery with a cell down is reading little over 10 volts
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,127
    17,793
    YO11 2BD
    My thoughts are as others have said......its both a hydrometer and electrolyte level indicator.
    If the water level is correct and the battery charged it will show green (usually) But....if the level is low but fully charged it will probably show black as the ball is too far down the tube to gather enough light to be fully visible.
    The specific gravity of electrolyte changes with charge state so taking a reading with a proper hydrometer is the only accurate way to determine charge state.
    Obviously not practical on many installations such as battery under seat etc so regular, seat off, maintenance is a must.
  11. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    with a sealed wet battery you can unscrew the sight glass with a pair long nose pliers and add distilled water which turns it from black to green as some batteries loose water over years and it gives a false reading yet the battery is ok
  12. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,507
    3,720
    Lost in La Mancha, Spain
    In a nut shell they are a waste of time, but for many it's something else to look at because it looks pretty...............
