Bart
I have a battery bank of 3 x 130 AH batteries, Today i had to remove them as i was doing some cable work behind the battery bank and that's when one of the 25 mm positive that goes between battery 2 & 3 connected with something Neutral , as the Positive cable was one going between batteries it was not fused.
Contact was for like half a sec but long enough to burn the edge of the positive lead.
After that i checked the voltage of the 3 batteries before i re connected them together and they were all reading 13.5 volts
After re assembling my battery bank my voltage was reading 13.5v
Could this of done any damage to my battery bank , and if so what ? and how could i check for such damage. ?
Also when using my 1500W Inverter from my battery bank of 390AH ( 3 x 130 AH batteries ) what is the Minimum Voltage that i should let the batteries drop to WHEN UNDER LOAD , with say the microwave going ?
