Popular with dealers though I wonder whyBanner being an Austrian company one of their biggest markets is Germany.
If you want to see how rubbish they are just search the German forms plenty of unhappy customers.
Big mark up?Popular with dealers though I wonder why
Aye, and they're rubbish at wars. And World cupsBanner being an Austrian company one of their biggest markets is Germany.
@Ovalball, I've gone down the same route as @Forestboy above, also with the expert help of @jonandshell .Banner batteries are crap mine lasted barely 18 months and failed when wilding in the Pyrenees.
We now have deep cycle traction batteries as recommended by @jonandshell.
3 years on massive use months on end off hookup and still going strong.
No more expensive than so called leisure batteries but a damn site better.
Good luck
Mainly as people want to buy them and are blinkered when we suggest an alternative.Popular with dealers though I wonder why
Lol Andy, need a 8mm nut on the nearest Positive stud!Three of these are 3 yrs old this month and the fourth was added 1 yr ago. They have so far spent their life exclusively feeding my 230volt circuits hair dryer toaster kettle etc. They are cheap and reliable, probably buy four for the price of two banners.
These were sold as Alphaline but now sold as Hankook
I thought that too Eddie, but seeing tools on the floor indicated that the job was still in hand.Lol Andy, need a 8mm nut on the nearest Positive stud!
How about this for a pile of poo, Hymer fit a Banner AGM battery for leisure use in a Motorhome, when they fail both Hymer & Banner will only accept batteries back under warranty if they fail a CAA test which is a starter battery test.When any battery, fails prematurely, why don't people complain or make a claim to the supplying dealer?
As Jock said Eddie but they're not 8mm either It is important to check that the nuts are with the battery on delivery as 8mm will only screw on three threads before seizingLol Andy, need a 8mm nut on the nearest Positive stud!
My batteries passed the CAA test but in leisure type use with my own tests which I fully charged each battery then applied a 5 amp load one lasted 10 A/H the other 12 A/H, the fact that they can survive a minute or so high current cranking test is irrelevant for leisure use.
It was about 2012 Hymer group started fitting Banner AGM batteries, due to the high number of failures (which they won't accept) they have in 2015 changed to Varta AGM's and on the German forums they are failing too, AGM's although when looking at their spec they look ideal for leisure use in practice they appear to be totally unsuitable.Hymer used to fit the EXIDE G80 gel battery to most if not all their vans, fitting Banner is just another penny pinching cut to me, but they are all doing it, the G80 I think is a cracking battery IMO.
Martin
Crap batteries, crap service = 100% Crap.It was so difficult to get any type of refund from Banner I gave up and took them to the scrapyard which is the best place for them, lifes too short to get worked up over a couple of batteries. The trouble with that attitude obviously is it means Banner keep getting away with selling crap.
They may be good at repairing Elektroblocks, but when it comes to batteries they have a very biased opinion and they are recommending a Starter Battery.
The more battery power the better if off grid a lot, in your position before adding more batteries I would ditch the Banners for a couple of decent batteries.After reading good reports about banner had two 115 fitted six months ago and must admit they are not giving me confidence is it any beneficial to fit four leisure batteries rather than just two I have a 130 panel on roof any fors or against please
Basically the way you tested them is fine except you should have calculated how long with the load would equal 25% of their capacity then removed the load after that time, let them settle for 30-60 min checked the voltage then repeated the test & repeat again, this would have given you a good idea of they capacity.I will start by stating I don't know what I'm talking about. Recently I had to retire 2 x 110 Platinum batteries after 2½ years. Having bought from a large on-line retailer I tried to claim on the 3 year guarantee, and the VERY disinterested salesman said that they'd take a look at them if I sent them back (at my own expense), but he couldn't promise anything. So I was faced with finding a carrier to do this and at a reasonable price. Almost impossible. So I asked him what was a 4 year guarantee worth on one of their own brand LBs. He just mumbled something.
I did wonder if it was just one battery gone, so charged them up with a good charger. One battery sat for weeks with a voltage of 12.83 volts after a few days, slowly dropping but still about 12.7v after a few weeks, the other 12.7 to 12.5. They seemed OK. So I attached a 20 watt light to the healthier battery, which was visibly dimmer after 12 hours, and was a pale glimmer after 24 hours total.
This lead me to think that although they were fully charged, the total amount of amperage left in the battery was considerably less, and had been reduced by usage, sulphated up or something. So my conclusion was that the voltage test was misleading.
I have replaced these by 1x135 amp to see how I get on, on the basis that it costs much less to replace if it doesn't last, then I'll think again about a traction battery. I have 2/100 watt solars, by the way. I'd welcome the input of an expert on this.
