Battery question
Discussion in 'Tech/Mech General' started by lorger, Nov 8, 2012.
  1. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Hi just after some advice on batteries.
    Today as i was just off night shift i was having a lazy day and then decided to go and pick up all the leaves from the garden and as there are loads i find the best way to do this is using my ride on lawn mower. This is where the problem starts as i haven't used it since beginning of oct the battery was flat.
    Took a while but here is the question the small battery says its 12v so could i use jump leads to start this off the car as i have loaned my battery charger to someone or would it cause damage
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i dont see why not gerry but i would leave it connected for a little while before starting the mower just to give the battery a little chance to redeem some charge.
  3. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,619
    5,689
    Yr Wyddgrug
    Gerry I have done this with my Brother-in-law's ride on mower. As Aba said leave it soak for a few minutes. It certainly hasn't caused any problems with his mower.
  4. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Thanks guys i thought it would be but not 100% sure will give it a go in morning there is still a little life in it just not enough to turn over engine and i cant be bothered raking them all as that would be like hard work :Rofl1::Rofl1:
  5. Philcott
    Philcott Read Only Funster
    Jul 17, 2012
    670
    370
    Bury St Edmunds
    The battery on my ride on is flat too and was wondering if a solar charger - the sort they use on electric fencing would work. Any thoughts anyone?
  6. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    To answer your question Yes.........on one of my ride on mowers the battery (about two years ago) would go flat after several weeks of no use..... in constant weekly use it would be no problem....I have two ride on tractors,....so I try to alternate the two tractors.... one tractor is a side chuck-er with one 36" blade...I use this one for the long and wet grass.when I come back after a month + away.. the other has a large rear discharge for finer cut on dry grass with a large catcher at the rear.... I use both tractors for the leaves that fall at this time of year.....one tractor will suck the leaves up like a vacuum then I add them to the compost heap...or the side chuck-er this chops them up into tiny bits like confetti to leave on the grass
    On the battery that did use to go flat I now I use one of those Lidl or Aldi small smart chargers cost about 12 euros... that you leave on the battery all the time ....they charge and discharge and de-sulphur the battery ....Brill never had any problems since ..like these below
    [​IMG]
    [​IMG]
  7. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Thanks Mal I actually have that charger just that I have loaned it to someone and won't see the until at work next week. Will try jump starting it tomorrow will let you know if it blows up lol
    • Like it Like it x 1
  8. maxsdad
    maxsdad Funster
    Oct 5, 2009
    299
    235
    anglesey
    Not another flat battery Gerry you are a bit to far away for a jump start this time.
    Should be no problem jump starting your mower as long as you are sure it is 12v.
    Remember your running time competition, my prize was a small solar charger kindly donated by Peter at Johns Cross. I have been using this on a transit van that i only use occasionally the alarm always discharged the battery after a while but this small solar panel has kept it charged over the summer not so sure about the winter though.
    They had the battery conditioners on sale for £12.99 at our local Aldi today
    Cheers dave e
  9. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Hi Dave
    Not having much luck with batteries yes i checked it today and it had big writing on it say 12V so should have it started and all my leaves collected in no time.
    Thants interesting about the solar charger Dave as i was thinking of getting one just to stick on the MH in case there's no friendly campers around to give me a jump :Rofl1::Rofl1:.
    Gerry
  10. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Hi folks just to say thanks for the advice got the ride on started after 5 mins soak, so no excuse now I have to tidiy garden today
