battery probs (1 Viewer)
smith123
29
st helens
coach built
not long
i have a chassion weclome28 on a transit base 06 plate all the 12volt equipment seems to be running off the cab battery and not the leisure battery is there a relay or somthing along them lines that could have failed
John H
253
24
Anglesey
coachbuilt
3rd year
Not sure if the van is new to you or if you've used it before. Is there a switch on the controle pannel that says"towing" and "onsite" or something like that ? it should in the on site position .
John
S
smith123
29
st helens
coach built
not long
no there is nothing like that on the control panal there ia the battery condition lights on the panal
John H
253
24
Anglesey
coachbuilt
3rd year
I dont know for sure but would think its got a relay that switches batterys when the ignition is switched off.
John
43,329
49,444
cheers john it must be a relay the thing is now is to locate it
the charge relay is NORMALLY as close to the battery as possible.
it should kick in when the engine starts, not just ignition on.
needs two people ......locate ANY relay near the battery and hold a finger on it while a mate startes the engine...you should feel it click.
any that doesnt should be treated with suspicion.
the easiest way is to disconnect the relays in turn, if more than one, and see if one kills the hab power. .
John H
253
24
Anglesey
coachbuilt
3rd year
thanks for your help can you tell me what the relays look like
cheers
They can be many colours, mainly black, sometimes yellow/blue/green. the smaller ones are about 25mm square usualy plastic cover with four wires coming out of one side or pushed flush into a fuse box etc.
John
S
smith123
29
st helens
coach built
not long
cheers all for all info its all fixed now found relay::bigsmile:
