battery power
Discussion in 'The Beginner' started by Kent monkey, Mar 25, 2015.
  1. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Halling village rochester kent
    Hi my battery is showing it's fully charged but inside the van the master switch is showing nothing and I can't turn anything on its been on ehu for ages any help please need it sorted as we are away for easter
  2. Bluemooner
    Bluemooner Funster Life Member
    Mar 30, 2012
    1,244
    1,685
    Ribble Valley
    Is the master switch turned on i spent ages trying to get my tv working i hadnt switched master switch on
  3. f6c
    f6c Funster
    Nov 7, 2010
    3,081
    832
    gloucestershire
    Welcome aboard;) Has the master switch fused?
  4. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Master switch is on.where would the fuse be for the master switch
  5. Bluemooner
    Mar 30, 2012
    1,244
    1,685
    Ribble Valley
    Not sure if you put what van you have somebody will come along and help
  6. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Sorry all new to me I have an auto quest 140.it's only 6 months old
  7. pops
    pops Funster
    May 1, 2012
    417
    362
    south glos
    On earlier ones they had a switch just inside the habitation door as well as the main master switch.
  8. pops
    pops Funster
    May 1, 2012
    417
    362
    south glos
    Just found a video of a 2013 model, is your control panel just inside door on upper left. have you found battery charger to check if there is a switch on it. Could be under one of the seats or in cupboard / wardrobe, have you got 240v at your mains sockets.
  9. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Hi yes there is 240 power.the switch is just inside the door. The battery is showing 13.6 if I put a meter on it.its just not showing anything inside the van
  10. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,846
    Is there a Aux/Veh switch on the control panel? If there is it should be set to Aux.
  11. bertiebasset
    bertiebasset Funster
    Jun 16, 2014
    296
    289
    NOTTINGHAM
    My Autocruise isolates the habitation electrics when the engine is running. Just a thought. :)
  12. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,402
    2,447
    Tunbridge Wells
    If it is only 6 months old I would phone the dealer. After all it is still under warranty
    • Like Like x 1
  13. pops
    pops Funster
    May 1, 2012
    417
    362
    south glos
    I agree with peterc10, Have you checked all the fuses. there should be a battery fuse, it could be near the battery or in the fuse box.
  14. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Have checked all the fuses all ok.spoke to the dealer he said dont know what that could be.I. Ll get back to you.so he was not that helpful
    I.
  15. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,402
    2,447
    Tunbridge Wells
    You are going to have to pay your tenner or you are not going to be able post any more. Believe me it is a good investment and has saved me hundreds of pounds with the advice I have got here.
    • Like Like x 2
  16. SteveG
    SteveG Read Only Funster
    Dec 22, 2014
    56
    49
    NW England
    I have an Autoquest (Marquis Majestic) 175 and the battery is isolated when ignition key is turned, or engine running. Caught me out first time
  17. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Not sure if mine is the same but engine was not switched on or running when I found out I had this problem am waiting for dealer to get back to me.
  18. Flook
    Flook Funster
    Jan 1, 2015
    121
    64
    Chelveston, Northants
    Hi all, this is my first post, and this battery issue sounds similar to a problem I have at this present time.
    It sounds like your leisure battery is dead. I have the Autoquest 175 Prestige, and have found if you disconnect your mains power cable so no power at all is being fed to your 140, turn on your master switch, how much power is being displayed. If it is zero, your leisure battery is dead, it may not be charging due to the charger unit having failed, you need to confirm this with your supplier.
    As I mentioned earlier, I have a similar issue, this started during a cold snap in February, I had mains power to the 175, had on the internal heating and left it running for a few days, I ventured out into the cold and into a cold MH? the heating had packed up?? I checked the power on the control panel and it read zero. I checked there was mains to the MH by switching on the microwave okay. After speaking to they guy's whome I purchased it from we determined it may be the leisure battery, and the charger may be at fault.
    I had permission from Elddis via the supplier to take the MH into an approved auto electricians, who confirmed the charger was naffed and changed it for me. He also confirmed there was a good chance the leisure battery was dead, he advised me what to do so when I arrived home I put the power back on and the MH power switch to OFF so the charger could do the work to the leisure battery and noting else. This was left for a few day's, I turned off the mains power which was reading just over 14v on charge. The reading with the power off was just over 12v. I did not check it again for a few days but when I did the leisure battery power was at ZERO.
    I attained permission to replaced the battery as the MH supplier is in North Wales, and I am in Northamptonshire, so a shade too far to travel. This week I replaced the battery with a new charged one, did not see any reason to fit the mains cable, and left it for two days, and now this one is dead, zero reading on the control panel. Have advised the supplier yesterday, now have the leisure battery on charge for over 24hours, and will leave on charge untill tomorrow, when I will recheck the power before I remove the mains, and will again leave for two day's. I am keeping my fingers crossed it won't die again, but I am keeping the suppliers informed at all times.
    Sorry my first post is not in the introductory section, anyway, I am Flook, this 175 is my first motorhome ever, I have been away only once, and enjoyed the few days I had. Sorry I say I had, there was my wife as well, and she loved the comfort and was surprised how well she slept in it.
    My real name is Dave, but there are so many Dave's around, so Flook is it, as there are not many Flooks around thank goodness.
    I hope you get your problem sorted Kent monkey, and your leisure battery is not like mine. Though I have a sneaky suspicion there may be an earth leak somewhere to cause this issue, and I may well have to leave it with an approved auto electrician for a few days, so I will see.
    Take it easy one and all
    • Like Like x 1
  19. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Hi floor your problem does sound similar to mine except my battery is fully charged and holding its charge my problem seems to be from the battery to the master switch the dealer I brought the motor home from is in Halifax and I. M in Kent so it's all being done on the phone at the momen they said they will talk to eddies and get back to me when I don't know.cheers
  20. Flook
    Flook Funster
    Jan 1, 2015
    121
    64
    KM, might I make a polite suggestion here, get back to your supplier on Monday, give them the morning to midday, then call them around one PM if possible. I have worked in the service industry and I appreciate certain things take time, especially when they have to be looked into.
    I have found out one thing about Elddis, they appear to be slow in response, I was fortunate as my problems started around the time of the Nation Exhibition in Birmingham a few weeks back, and they spoke to Elddis at the show, so Elddis pulled out all the stops.
    However, should you feel you are not getting anywhere, why not contact Elddis direct, tell them you problems and take it from there.
    By the way, what is the amperage of your battery, mine is 110ah and in theory should last 100 hours, though it is not said what you can/cannot use, so I would assume that is a standing time.
    I have just re-read your original post, when you operate your switch does it make a click? when you turn it on! You can activate one of your other switches to feel and hear what it is like. It may just be a faulty switch.
    How do you know your battery is up to full power? what checks have you done to check the actual amp hour rating?
    In your van there should be a bank of switches, similar to the ones you have in houses but smaller (these are called MCB's for Miniature Circuit Breakers), these should be referenced to in your Elddis hand book. Read that book on that section, check it out to your van, see if any switch in that unit looks different to the others. If I recall correctly they should all be in the up position, so visually checking these will give you an idea of what is what. If one is in the down position, check first what switch it is by taking either a mental note or a written one. then with the main van power switch in the off position go back and flip the the switch to the up position, turn the van power switch on, check the MCB's to visually check if any have been activated. If the same one has been activated you know you have an issue with that circuit, of they are all as they should be then try the power to your home.
    One way of making sure the van power can be taken off your battery is ensure your mains cable to the van is disconnected (not van side), otherwise you may be using the mains power as the power back up and not the battery, with the disconnection you will be relying solely on the battery to power up your lighting/heating and all other 12v items.
    Sorry I seem to have gone on a bit, possibly said things you have already checked out. It may come down to having an approved Elddis auto electrician to look at it, if you have to wait too long, ask Elddis or your MH supplier (prefered) if they would accept if you paid for an approved auto electrician to check it out for you, and ask them if they would then re-reimburse you your cost, especially if a problem was found and rectified, especially as time for you is of the essence.
    Flook
