Battery power usage (1 Viewer)
mickcope
65
10
essex
hi top
OK - i know this is a piece of string question.... but we have a booked a two night festival with our motor home (Maverick in Suffolk). All the camping we have done so far has been on 'proper' sites so have not relied on battery power. So if we use the standard leisure battery for lights (its in July so not too much), some water pump and charging of iPads and phones - will the battery last us ???
If not do we go for 2nd battery or small portable solar panel?
thanks as ever for your help
cheers
MIck
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
If your battery is in good condition it should be sufficient for the use you have described, especially if you have LED lights.... :thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
small solar panel???? wash your mouth out, hee hee get a big one 80W fixed to the roof and be power independant.
43,319
49,372
an 85ah battery will give you around 40 amps to play with (50% discharge)
standard 10 watt halogen lights should use near enough 1amp per hour each.
water pump around 10amps but only used for a few seconds at a time, except for showering.
even running the pump for an hour total is only 25% of your capacity.
phone/ipad charging negligible. (milliamps)
if your battery is in good nick it should be no problem for a couple of days.
Pigwam
45
8
Chester
Since 2011
Of course this is next year we are talking about and a lot can happen to your batteries between now and then.:Smile:
