Battery not holding charge (1 Viewer)
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
Hi, i have two lesuire batteries, which are wired together if one of these batteries is starting to fail does this affect the other battery, does it trick the charger with the good battery altering the 3 stage intelligent charger to miss a stage of charging and just go to maintenance?
is it advisable to replace the failing battery imediately
pete
TheBig1
17,620
43,217
if one battery drops a cell or gets sulphated it will drag the good one own and damage it too. the charger will be working hard trying to boost charge but nothing gets in
be prepared to replace both
Feb 24, 2013
13,077
101,439
Bolsover, Derbyshire
Hymer S800
not long enough
When I bought my current MH, from a private seller, I had not noticed he only demonstrated everything on EHU
I was mortified when I stopped on the way home and nothing worked
Turned out one of my 2 batteries had failed and dragged the other down so it looked like both were US
So I bought 2 new, fitted them and then found out I had a perfectly good one still :Doh:
Good news it is now running an electric fence in Spain at a friends house keeping foxes off his chickens so not all bad!!
Hopefully you only need one as well
David
