Battery Master - Swift Sundance
Discussion in 'Motorhome Chat' started by Wollow007, Feb 15, 2012.
  1. Wollow007
    Wollow007 Read Only Funster
    Dec 17, 2011
    36
    Reading
    Hi Guy's n Girls,
    I have purchased a battery master and wish to install it this weekend.
    I understand what needs to be done, but unsure where best to connect the unit to reduce new cabling etc.
    Anyone installed in a Swift, year is 2003.
    Any experience or ideas appreciated :thumb:
    Cheers :Smile:
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Best bet is to locate your split charge relay. You will have one lead coming from the leisure, and one coming from the engine battery. Once you have located these, slide the casing back with some side cutters - be gentle, and do not break the wire. Wrap the corresponding outlet from your battery master around and solder in place. Tape it up secure, Pop the earth wire on and you should be good to go.:thumb:
    • Like it Like it x 1
  3. Wollow007
    Dec 17, 2011
    36
    Reading
    Any idea where I would find the replay?
  4. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    I am afraid the words are 'seek and ye shall find'...depending on the conversion etc, they can pretty much be anywhere between the two. I would logically start my search from the engine compartment and work back. If you locate the alternator, there will be a feed going to the alternators charge wire, so by following that back you will find the relay itself.
    Some are quite discrete, others will be prominently placed and quite visable. If in the engine compartment, it should be fairly high up to protect from water, though it could be under the dash. Maybe a call to the converters may tell you where they 'normally' put it if you have no joy finding it yourself.
    I would check from the alt wire backwards as this will be the easiest way if it isn't visable.
