Battery master installation
Discussion in 'Motorhome Chat' started by Nirvanauk, Jan 31, 2014.
  1. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,398
    7,328
    God's county. North Yorkshire.
    So, it arrived and I was told it was easy! Call in an auto electrician that tells me that the drivers seat has to come out at huge expense to access the leisure battery. Then needs access to the engine battery to connect the other wires. Call the seller who says it needs to be connected across the split charge relay, but where the hell is that because I don't know!:Sad: email the manufacturer who tells me that yes, that is right ( ??. ) and they can sell me a battery master for £50 but I've already bought one!
    So, does anyone know how to install one of these please?
    Many thanks.
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,345
    34,930
    Electrically, installation is simple. If it is the same as the ones I have installed you just need connections to both battery positive terminals and to the common earth.
    Routing the cables between the unit and the two batteries will depend on where the batteries are located. I found it reasonably easy in an Autoquest 100. In most cases (as with the Autoquest) it will require finding a way to run a cable between the engine bay and the main body of the van.
  3. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,638
    14,303
    North Lincolnshire
    Huge expense to remove a seat?:Eeek:
    Is he on planet Earth or Fuller's Earth?
    • Like Like x 2
    • Funny Funny x 1
  4. movan
    movan Funster Life Member
    Dec 2, 2009
    13,576
    24,494
    Moving around
    My split relay was actually found in the engine on my last van .... sorry if this doesn't help and is daft, but I didn't know where it was.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,555
    YO11 2BD
    agreed.....2 x 13mm bolts at the front of the seat box and 2 torx or Allen bolts at the rear IN the seat runners...seat removed in less than 10 minutes.
    This guy must be on a hell of a good hourly rate. :Eeek:
    • Like Like x 2
  6. scotjimland
    Jul 25, 2007
    28,934
    25,601
    dead simple.. here is drawing
    [​IMG]
  7. movan
    Dec 2, 2009
    13,576
    24,494
    Moving around
    bump
  8. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,398
    7,328
    But does anyone know where to find the split charge relay on a Renault Master PVC built by Timberland ?
  9. scotjimland
    Jul 25, 2007
    28,934
    25,601
    You don't need to find it or connect to it.. that is just a convenient place to pick up the 12volts from the engine battery..
    personally I wouldn't bother looking, just go directly to the pos on the battery as per diagram.
  10. Larby
    Larby Funster
    Jun 17, 2012
    1,715
    3,988
    North Essex
    Mine is a Fiat and has relay under the bonnet under a black cover.
    The wire at leisure battery is brown with blue tracer, the live from battery is brown.
    I connected the Battery master as shown.
    Red to the brown/blue
    Brown to brown
    Black to earth
    • Like Like x 2
  11. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Larby, thanks for the photo.
    What relay is it that you have connected into there?
    I'm interested as it looks like my next job with the Son's MoHo.:Angry:
    Regards,
    Trikeman. :Wink:
  12. Larby
    Larby Funster
    Jun 17, 2012
    1,715
    3,988
    North Essex
    It's the split charge relay, proven by the brown/blue wire as coming from the leisure battery and permanent 12v from battery.
    Nice and easy to locate both wires. Also proven with multi-meter.
    I also found this useful , has a wiring diagram
    http://assets.swiftgroup.co.uk/uplo... Books/1053128 Swift MH Service Book 2004.pdf
    • Like Like x 1
  13. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Cheers Larby,
    yep, makes sense now - thanks.:thumb:
    Regards,
    Trikeman. :Wink:
  14. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,510
    9,935
    its perfectly ok to piggyback the connections onto the split charge relay, just make sure it is the battery relay not the fridge relay. often found in the engine bay or near the battery, look for a non standard fused wire coming off the van battery +ve feeding a relay. there will normally be 2 so check the outgoing wire from the relay (the other thick one) and check that it feeds to the battery not the fridge. easy to do with a meter as it will show a positive voltage with engine off, just like the one from the battery. the fridge feed will be off with engine off
    it should take a decent auto electrician about 15 minutes to fit and doesnt need the seat taking out usually
  15. musson
    musson Funster
    Dec 25, 2013
    401
    140
    grantham
    I have a bessacarr E584 fitted with sargent panel it says it will switch to engine battery from leisure when the voltage gets to low using my solar panel are we saying it is still advisable to fit a battery master?
  16. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,386
    2,656
    Surrey
    Yes.The Sargent will only do that when it is controlling the charge. Solar controllers are separate, and will tend to only charge the leisure batteries. Thus you can end up with full leisures and drained cab battery if you haven't got a hookup.
  17. treetops1
    treetops1 Funster
    Feb 25, 2013
    952
    1,099
    yorkshire
    Worth having a word with Andy (Tecno) he fitted mine in a few minutes instead of the couple of hrs running wires around I was expecting to do.
    • Like Like x 1
    • Funny Funny x 1
  18. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,159
    1,927
    Cannock Staffordshire
    Fitting a battery master was one of the simplist things I've done, 3 wires.. Even if a seat has to be removed its really basic stuff, some of these so called experts really take the fkin piss just so they can over charge you.
    • Like Like x 1
  19. TheBig1
    Nov 27, 2011
    7,510
    9,935
    so very very simple. + and - on the leisure battery and run just 1 wire to the + on the cab battery
    • Like Like x 2
  20. PeteH
    PeteH Funster
    Nov 22, 2007
    2,084
    2,620
    East Yorkshire
    Can someone explain the benefits of the "battery master" type installation?. All I had was a Wire, two crock clips a Large Diode and a 30amp Fuse, between the 2 sets of batteries, so that when on mains (or Solar) charge the Chassis battery was kept topped up?. Seems a lot of extra cash for the same?.
