Battery Links
Discussion in 'Tech/Mech General' started by norsman, Mar 24, 2008.
  1. norsman
    norsman Read Only Funster
    Jan 10, 2008
    8
    Nth Lincolnshire
    Hello
    can anyone give us advice on how our batteries should be connected. i know it sounds daft and i am not generally a daft lad, but i cant understand why the leisure battery is connected to the coach batteries. when we were away on our first trip the batterries went flat even after being hooked up.am i missing the point here somewhere. any thoughts would be good.
    geoff & lynn.
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Found this site.Seems pretty comprehensive.:thumb:split charge
    [​IMG]
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  4. norsman
    Jan 10, 2008
    8
    Nth Lincolnshire
    battrey links
    thanks for the input, i am going to fit new batteries tommorow so i will try to follow the diagrams you gave me. i think my problem i have is buying some one elses little cok ups.
  5. TJ-RV
    TJ-RV Deleted User
    For my edification, could someone confirm the use of the terms leisure battery and coach battery. In the first post, coach battery appears to refer to the starting battery, while leisure battery appears to be the battery that runs all the non-chassis 12V stuff.
    We Yanks use slightly different terminology:
    Chassis or stating battery: Starts the engine and powers head/tail/brake lights, indicators, dash and, in the case of petrol engines, ignition. Often, the entry steps are powered by the same battery.
    House or coach battery: Powers all the 12V stuff in the living area, including lights, refrigerator, and slideouts.
    Diolch yn fawr as we used to say in Wales, or ta much.
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi TJ-RV you have it right:thumb:
    terry
  7. TJ-RV
    TJ-RV Deleted User
    Thanks Terry. I'll get our Glossary of RV Terms updated to cross-reference Britspeak for batteries. That way, when folks ask about coach batteries, we know they really mean coach batteries.
  8. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,677
    5,831
    Mansfield,Notts
    Hi Tom
    Then you might like to add another
    Starter Battery=Starter Battery
    Habbitation Battery= House Battery:Doh:
    Geo
    You Should include a link to your site Tom, in your Signature
    I would then cross the water and have alook at yall
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Tom just to make things as clear as mud on most British vans the starter batt only runs the van side of things-starting ,lights indecaters etc,the leisure battery runs just about everything in the caravan (back) side of things -lighting, heating, tv,etc,Then we have relays which charge leisure batterys from engine and also run fridge (12v)whilst engine is running:Rofl1::Eeek: clear?:Doh:
    terry
  10. johnsandywhite
    johnsandywhite Read Only Funster
    Jul 29, 2007
    2,348
    15
    Doncaster/Spain
    :RollEyes: Not necessarily so. Our 1989 Kontiki allows you to switch between the Starter and the Leisure battery. :Wink:
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    :Rofl1::Rofl1::Rofl1::Eeek:Told you on most & clear as mud :thumb::Rofl1::Rofl1::Rofl1:
    terry
  12. Digger Driver
    Digger Driver Read Only Funster
    Oct 4, 2007
    578
    Lancashire
    To be honest!
    I don't like the charging relay thingy's!
    In my transit i had a battery isolator switch fitted on a butchered jump lead between the starter and the habitation batteries and just switched over when i wanted to charge either!
    I found this way charged much quicker and you could use the habitation battery to boost the starter if it was needed as well as the habitation hook up charger!
    I had two basic battery testers connected to monitor charging which gave me far more information than i have now!
    All in all the set up in the van was much better than the set up in the Kon Tiki.
    I could charge to capacity 3 lorry batteries i had for habitation with the van idling for an hour and a half using a cup of deisel!
    I know a lot of diesel fitters set up their vans this way and was wondering if you guys knew any reason why i shouldn't do it to the Kon-Tiki!
  13. TJ-RV
    TJ-RV Deleted User
    Thanks Terry, we have that stuff on our coach also. If you want to see some battery fun, we have 15 batteries on our boat:
    • Each of the 660 HP CAT engines has a large 8D battery for starting.
    • 2 more 8D batteries are connected in series to provide 24V and high current for the bow thruster. (It takes some oomph to move 50,000 lbs/25,000 Kg sideways.)
    • The 10KW generator has a dedicated car-style battery for starting.
    • 10 golf cart style 6V batteries connected in series-parallel provide 1100 amp hours at 12V to run the inverter which produces 120V AC when we're afloat and away from shore power and don't want to run the generator.
    As the 8D flooded cell batteries quit, I replaced them 8D AGM batteries, and replaced the generator battery with AGM also, which makes the job of checking and topping off water a bit easier.
    There are 4 separate charging systems on board, excluding the engine-mounted alternators.
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    i hope you get a very long life from these, at over £300 each you dont want to have to change them to often.:Eeek::Eek!:
    john.
  15. TJ-RV
    TJ-RV Deleted User
    Thanks, I think. So, if you have more than one type of battery in the system, does that make them co-habitating batteries?
    I don't come here to advertise our forum and think it's bad form to do so. But you could Google us; We're the oldest RV-related online forum and claim to be the friendliest place on the web for anyone with an RV or an interest in RVing. You'll know you're there when you see the real me in my avatar and my name below it.
  16. TJ-RV
    TJ-RV Deleted User
    John,
    It's always a big ouch when they fail and I have to dig deep into my pockets.
  17. pappajohn
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    can you not do some diy recycling and fix the dead ones to a length of chain, chuck 'em overboard and use 'em as sea anchors.:Rofl1::Rofl1: bet they weigh a ton.:thumb:
  18. TJ-RV
    TJ-RV Deleted User
    Good idea, but the environmentalists would get me hauled into court if I did that.
  19. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Tom,:Rofl1: ditch the cat engine and just run on battery power :thumb::Rofl1::Rofl1
    terry
  20. TJ-RV
    TJ-RV Deleted User
    LOL Terry, not a bad idea. That would save a lot of fuel, but the boat would only go sideways :BigGrin: BTW there are two of those big CATs on the old tub and they suck a lot of fuel. Makes filling the coach seem cheap. It's all relative I suppose.
