Battery isolator switch (1 Viewer)
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
I would like to fit an isolator switch to my vehicle battery. For security and to protect it from the persistent drain of amps. My question is, do I put it in the battery negative terminal - to chassis cable ?
Are there implications for the leisure batteries, who are also earthed to the chassis ?
Dec 10, 2013
3,423
12,216
South Staffs
Pilote P740GJ
Since 2013
Don't know what year your motorhome is but if it is a newish one you may have problems if you isolate the vehicle battery. The radio code for one and I had a car that the dealer had to reset the airbag warning light after the battery had been disconnected.
TheBig1
17,628
43,233
its easier and electrically the same to isolate the negative side of the battery. as the leisure battery is or should be isolated from the charging circuit by a relay, no issues there either
dont forget to fit a decent amperage isolator, as all the cranking current will be drawn through it
Moodybrook
Moodybrook
802
651
still in nappies
I thought the negative side looked the easiest but I am prepared to be wrong. This ok ? Broken Link Removed
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
The spec on that is quite good, pity the don't supply the ring connectors you will need but ho hum.
TheBig1
17,628
43,233
that should do as it is rated at 1400amps for 10 seconds
as for fitting ring terminals on heavy cable, dont even try if you dont have the correct equipment. measure up the lengths needed and buy them ready made. either at a motor factors or plenty of sellers on eBay will make them up at a good price
Broken Link Removed
Moodybrook
Moodybrook
802
651
still in nappies
Thanks to all, (y) will get made up cable connectors, too much juice floating about to mess about with.
Mike that is ok but would mean lifting mats, opening up the vehicle battery box under the floor etc so I think switch in the cab with a removable key for additional security would suit me better. :) I found one with a security key, not the plain standard one that could be operated with a simple screwdriver :)
